Results 1 to 7 of 7
Thread: F3T Spark plugs
    Active Member fencepost's Avatar
    Apr 2010
    Thorn Hill, TN
    Default F3T Spark plugs
    Has anyone replaced the spark plugs on their F3? I have 31K on the bike and service says change at 29K. How much of the plastic needs to come off? Any short cuts?
    SpYderman
    Apr 2016
    Alberta
    I made this video last year, should be the same for the f3T though.
    https://m.youtube.com/watch?v=G_3SmRPmxs8
    Mar 2017
    Quote Originally Posted by BFB View Post
    Not looking forward to this chore!
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default yup
    yup.....
    i did my F3 this past March.... took me 2 days, 5 hrs each day.... @ 70 yrs old, it's a killer....
    you'll need to take off the entire upper Tupperware... left front headlite, air-box.... NOT FUN...
    while you're at it, get a FUEL FILTER... b'kuz it's basically the same process to replace that little thing...
    mine had 41,000 miles of smiles on her when i changed those 3 little buggers... and i'm here to tell you that the plugs i pulled out still look in EXCELLENT CONDITION.... the OEM plugs are 'iridium' plugs, and in my book, they're good for 100,000 miles of riding...
    however, the book says to R&R them @ 28K....
    20180319_140008 (1).jpg 20180319_151113 (1).jpg 20180319_154832.jpg 20180320_125656.jpg 20180320_132434.jpg
    best of luck...
    Dan
    SPYD3R
    Sep 2013
    Houston
    I replaced a set that had over 60k on them and still not worn, were clean and the gap in spec. For me, if the bike is running and idling smoothly, the plugs are fine.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    On my '14 RT I replaced mine at 40k miles and once removed they were noticeably worn and in need of replacement. I can't account for the differences between bikes. As stated BRP use Iridium tipped plugs that in theory should last 100k miles. However, on my bike there is no way they would have lasted even 50k miles, they were that badly worn.
    2020 RTL SE6
    Apr 2018
    BCC, AZ
    Default Plug change..
    After watching the video..I'll wait until I see a performance problem..and replace the fuel filter at the same time. I had a 2010 ford I changed the plugs at 107k and they looked good. The truck had 320k on it when sold with over 200k on the plugs..the newer plugs and ignition systems are much longer lived..save your money...
