Results 1 to 12 of 12
Thread: stranded
    Nov 2013
    pa.
    Default stranded
    we have a 2015 rt limited with just over 20,000 miles. serviced according to the manual. about 8 miles from the dealership the bike would not move-grinding when either 1st or reverse. luckily the dealership was able to pick up the spyder. no word back on the problem...any one have any ideas? thanks
    Mar 2017
    Salisbury,NC
    ouch.....even tho its not an F3, there are some front sprocket RT failures. look it up
    Quote Originally Posted by daviszoo1 View Post
    It sounds like your gear shift "actuator." When they disconnect, the bike will not go into gear. Coincidentally, this happened to me just this weekend. Mine happened somewhere between Wasilla and home--(20 miles). It will not go into reverse--but I still have my forward gears. Mine made it to my garage--so--so far, no tow bill.
    Going to take it to the dealer this week. This happened to me one time before with my 2010. 30 minutes and about $50 later--I was good to go. Here's hoping the same for both of us.
    Sep 2016
    clark county indiana
    Default S-E 5 or the S-m 5
    which cycle clutch or auto ? most likely auto ... ( It sounds like your gear shift "actuator." When they disconnect, the bike will not go into gear ) is this a vacuum actuator ? --------- are they now referred too as S-M 6 `s and so on ?
    Nov 2012
    North Las Vegas, NV
    It’s an SE6 (semiautomatic) and for info limited comes in SE only. To the OP, sounds like the front drive sprocket.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jun 2014
    Muskego, WI
    So what happend in this incident? How can you post something like this and not do an after repair report? Geeez....
    Rick H.
    Northern Kalifornia
    Rick H.
    Maybe still in the shop waiting for parts that are on back order.
    Jun 2014
    Muskego, WI
    Could be 2 Dogs, but the diagnosis should have been done if that's the case. I just hate a story without an ending especially if it may help someone else out later on....
    Rick H.
    UPDATE on mine. Replaced shift actuator. Cost $181 parts & labor.
    Feb 2012
    Spring City,Utah
    Was this on your '14 or the '11
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    This time, it was on the 2014 (32K miles). It did happen on my 2010 early on though. Happened a mile or so from the dealer--limped it in and they fixed it on the spot. NO charge to me. Those were the days.
    Jun 2014
    Muskego, WI
    Thank you for letting us know the outcome!
    Rick H.
