Results 1 to 9 of 9
Thread: Rear brake
    Oct 2007
    watsonville CA
    Default Rear brake
    Found a use for the rear brake pad.
    Jan 2015
    Florence, Oregon
    Smile Old Brake Pads never Die!
    Good idea!
    Jul 2011
    Cleveland, Ohio
    Default WOW what a good idea!!
    Quote Originally Posted by ivanlee View Post
    I am going to make one for my car as well. I can get rid of the "C" clamps. WOW what a good idea.
    Chris
    One of the FIRST to own a Spyder 2008 No.2817 Premier Edition Spyder GS. I knew a good thing when I saw it!!
    2016 F3-T, LED Headlights, Frnt. & Bck. Side Marker Lights, Back Frnt. Fender Lights, Trailer Hitch. Floor Boards Frnt. and Bck. Third Brake light. Cannonball seats. F4 24" windshileld. ( CAT Delete Pipe (muffler bck. on) ) 2003 Valkyrie
    Very Active Member sealfloorboards's Avatar
    Aug 2010
    Newberg, Or.
    Sorry, but I'm not a mechanic. What am I looking at?
    Oct 2007
    watsonville CA
    Quote Originally Posted by sealfloorboards View Post
    You can push your piston back into cyl, hold your piston in place , bleed your your rear brake cyl. No danger of hitting your brake pedal and pushing out the piston on your rear brake cyl.
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    Default Rear brake
    I SpyderMan.
    I have a question, When have the rear brake pad changed, do not let the parking brake be so no buzz, which fuse must be removed to stop de buzz ?
    I am new owner of Spyder RT LTD 2014
    Tank You
    FlyBoy2121
    2014 RT ltd , original original Cognac
    Nov 2017
    San Francisco Bay area
    Thank you, I thought I could use it to open a beer or something!
    2015 RTL , Yes Pearl White
    Active Member Joerolwing's Avatar
    May 2016
    Nashville, TN
    Quote Originally Posted by FlyBoy2121 View Post
    I SpyderMan.
    Tank You
    FlyBoy2121
    It will stop on its own in about 30 seconds
    Aug 2018
    Canada
    Default Rear brake
    I Joerolwing
    Thank you I will try this tomorrow morning.
    Quote Originally Posted by Joerolwing View Post
