Results 1 to 23 of 23
    Jul 2018
    Saskatchewan
    Question Newby and RT cruise control
    When I cancel cruise control either via touching the brake pedal on shutting off cruise, my 2015 RT decelerates very noticeably. Is this “normal” for these machines?
    Jun 2010
    Las Vegas
    It would do that if you aren’t giving it any throttle. I always use the brake to disengage it, I always leave it in the On position so I only have to set or resume to cruise again.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Dec 2017
    Palm Beach County
    Yes.... normal
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    I roll on the throttle just until I can tell there is a little load on the engine before I tap the brake pedal. I learned pretty quickly that my copilot didn't appreciate the sudden deceleration that occurred if I didn't. It does make a smoother ride for the passenger if you do that consistently.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Apr 2017
    North Central Florida
    Yes.
    All good answers so far.
    I find that I use the brakes very little on my RT.
    The transmission downshifting and engine compression slows it down rather quickly.
    You DO need to get in the habit of watching your mirrors for tail-gaters though........and tap the pedal so that the brake lights come on.
    Aug 2013
    Northern California
    I agree with Ann, no need to turn it off! Use the brake.
    Active Member Triple B's Avatar
    Jul 2017
    British Columbia, Canada 🇨🇦
    Quote Originally Posted by SpyderAnn01 View Post
    +1.......and yes, a very noticible deceleration. Be sure to check your mirrors before deceleration.
    Bruce
    2014 RTS-SE6
    Tri-Axis Handlebars
    Sena BT Dongle
    Sirius Radio
    Dash bar
    Show Chrome Trunk Rack
    "You know that a politician is lying if his lips are moving"
    I'm pretty "anal" about switching it off...
    But I roll the throttle on, as I'm thumbing the button: it's a dance that you can quickly learn!
    Jun 2010
    Las Vegas
    Curious as to why you always shut it off? If I turn mine off it likely wasn’t intentional.
    2010 RT- 622
    Jun 2015
    St Petersburg, Fl
    I leave mine on constantly. That way the cluster reads "Cruise On" which I take as a directive.
    As I said: I'm anal about shutting things off; that aren't being used.
    It's just how I roll!
    Bryant, Arkansas
    I turn mine off everytime because I have a bad habit of accelerating while the cruise is on and then forgetting that it is set and when I decelerate, expecting it to slow down, it keeps going and I have to deactivate it quicker than I was expecting to
    cruzr joe
    Very Active Member 2Paw's Avatar
    Feb 2013
    USA, Texas, Mckinney
    cruzr joe
    I deal with the same issue the same way as you do.
    Ed
    They told me not to give up on my dreams, so I went back to sleep.
    Champagne 2017 RTS SE6
    Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
    Sep 2011
    North Central Illinois
    You have been given the remedy to your problem in some of these posts.
    Thought I would add this paragraph from the Do's and Do Not's for New Spyder Owners thread:
    Cruise Control Hint:
    When disengaging the cruise control the Spyder makes an abrupt slow down.
    To eliminate this, slightly "roll-on" the throttle (as if slightly accelerating) before tapping the brakes or switching-off the cruise.
    When doing so, the cruise control will disengage smoothly without any jerking motion of a slow down.
    Practice this a couple times until you see how easy it is to solve this problem.
    (As Bob mentioned, the dance is easy to learn after a few times.)
    SL #7026
    VBA #652
    HOG #3935417
    2011 Viper-Red Spyder RT SE5 & Trailer
    2017 HD Ultra Limited
    Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
    Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Quote Originally Posted by BoilerAnimal View Post
    Absolutely right.... That is what do when I dis-engage the ""COPILOT".....
    2018 RT Limited "Blondie"
    Another card on the pile for leaving it "on" all the time. On the other side--Linda never uses hers.
    Jan 2015
    southern WI
    Yup, normal. When I go to turn the cruise off, I press down on the button and then tap the brake at the same time....makes a nice transition without the harsh deceleration.
    2021 RT Limited
    2016 RTS , Pearl White
    If you don't think that it's normal: shut off the cruise control in your car at highway speeds...
    Idaho
    Quote Originally Posted by Geep View Post
    Yes. One reason is the engine has no flywheel so there is not a great amount of rotating mass keep the engine spinning when the cruise is turned off, or when the throttle is turned off quickly.
    I leave mine on all the time. Disengage with the brake or by shifting (I think! Can't remember nuthin any more! )
    2014 Copper RTS
    Jun 2010
    Las Vegas
    cruzr joe
    I accelerate with the cruise on all the time but I use the up button on the cruise instead of the throttle.
    2010 RT- 622
    Jul 2014
    Mint Hill, NC
    Throw me on the pile that leaves CC on all the time and kills it with the brake pedal. If you want to kill the CC wthout rapid deceleration just roll on some throttle before nudging the brake. With practice you'll learn how much throttle you'll have to roll on for a given speed.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Sep 2016
    Clifton Springs, NY
    I leave mine on all of time also and just hit set when I want to use it. One thing I wish it had was a "Cancel" button like a car. No biggie to hit the brake pedal or turn the cruise off but a way to cancel by the button would be nice.
    Wayne Bishop
    2015 RT-S Special Series
    2017 F3 Limited
    Apr 2017
    Quote Originally Posted by wrb3004 View Post
    You turn it OFF and then immediately back ON. Of course, you lose the setting when you do that.
    Mine stays ON all the time.
