Results 1 to 14 of 14
    Active Member John Moody's Avatar
    May 2015
    Urbana, Ohio
    Default how to replace fog light bulbs
    Both fog lights/blubs burned out 3 weeks apart on my 2014 RTL. Need to know how to replace blubs, will I need to removed the front nose.
    Aug 2013
    SF Bay Area
    You'd be surprised at how much you can learn on Youtube.
    2021 F3 Ltd , Magna Red
    The right one is the easy side; not so the left.
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Default Good information
    I’m replacing my headlights and fog lights this Saturday. I’ll take any help I can get ..!! I wish these machines came with led lights ..! They should have for what we paid .. (in my opinion)...!
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Dec 2015
    Oakley Utah
    I doubt this will be much help. It only shows the right side, which is relatively easy to access. What is needed is instructions on replacing the left fog light on an RT, which involves; a) really skinny strong hands or b) removing the frunk or c) removing the air intake tube.
    Maybe a video about removing the frunk would be most appropriate?
    Meanwhile, I found these written instructions from an earlier thread; http://instructions.brp.com/content/...mber=219400137
    2014 RTL Platinum
    Mar 2015
    forrest above Reno, Nv
    Default Poor design
    Strong hands and move ( not necessarily re move ) the air intake tube. Good lighting helps also. Put in LED lights.
    But it is poor design. Just like my wifes Chevy Equinox Sport----- you have to remove the grill to change the headlights.
    Lew L
    2014 RTS , Circuit Yellow
    Jul 2010
    Las Vegas, NV
    Default Patience
    The trick is a 18” long #2 flat tip screwdriver. Slip in, twist, remove cover. Work cover out. Now trim 1/8th” off the bottom tab, following the curve. Replace bulb, replace cover. We use a 1” diameter wood dowel about 18” Long to pry the snorkel out of the way.
    Joe Meyer
    Jun 2017
    Texas
    Quote Originally Posted by cptjam View Post
    Thank you Joe for the information..!
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
    Dec 2015
    Oakley Utah
    I'll have to try that one next time!
    2014 RTL Platinum
    Jun 2010
    Las Vegas
    Band-aids are usually required to repair the knuckles of the installer.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Aug 2018
    north wis
    You can move snorkel enough without removing trim panel from around fog lights?Just did headlights,haven't buttoned up yet but thinkin I need to return the fog bulbs!Just not up for pulling frunk and whole front end...
    Jul 2010
    Las Vegas, NV
    Quote Originally Posted by woods View Post
    nope, leave the trim alone. Use a broomstick, pry the snorkel out of the way to reinstall the cover. Get a helper, it is much easier! Trim 1/8” off the tab on the bottom, goes on much easier! Take your time, it will go on. Or, meet me in Texas hill country. I’ll put it on for you! I’m leaving for Texas Sunday morning. I’ll have my phone on. Call if you need me. Joe
    Joe Meyer
    Aug 2018
    north wis
    Thanks,I'll try it!
    Aug 2018
    north wis
    Took a whole lotta time and tryin but it went!While trying to put cover back on I just kept tellin myself"It came off,gotta go back!"Suddenly you hit the harry potter spot and it falls together!Still,hoping I never have to do it again!Thanks all for the help!
