Horns
I have been thinking about replacing the factory horn with one a bit louder. Any suggestions?
Stebel is the way to go,install with relay.I have used them on every bike I have owned,you will get noticed when you hit the button.Amazon sells the complete setup,horn wiring,relay very reasonable.
Wolo Bad Boy is good too. Pretty much the same as a Stebel. Pretty cheap at Harbor Freight, $30.00 with the 20% discount coupon. It comes with the relay that you will need and a 20 amp fuse link. You supply the fuse. It's a regular glass cylinder automotive fuse. Pretty loud at 112 db. I have one, and like it a lot.
I think it helps
I replaced my stock 2015 RTL horn with an air horn and I think it helps get more attention.
Rob
2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
Here's what I did...
I had the Rolo Bad Boy that I had installed instead of the oem but was not happy with it. Now I got a low tone high decibel horn and added it to the oem and got what I wanted...
the oem is it's original position.
2012 RS sm5
I have the Stebel air horn on my Honda. I was thinking about adding it to my Spyder RT but decided to install the twin electric horns from Rivco. I also used the Rivco wiring kit made specifically for the Spyder. It all worked great. I think the electric horns are just as loud as my Stebel air horn. What was nice was having all the wiring and mounting brackets from Rivco without have to fabricate anything.
I did have the twin Rivco chrome air horns on my Valkyrie with remote air compressor...talk about waking up someone up at the stop light! LOL
Gunner
Dual horns on my 2017 RTL
Replaced the quiet with the dual horns, I get there attention now, both the horns and the small compressor are located in the place as the old one was located right by the left foot.
Add On’s
2017 Pearl White RTL
SPYDER RAM Multi Mount
Ram Mount Drivers cup holder
Ram Mount passenger Cup Holder
TRICELED Bar/Circle
Brake Light/RGB LED
Ground Effects Lighting
Airhorn/compressor
LED Head Lights
LED Fog Lights
K & N Air filter
Two Brothers SR1
Cat Bypass Pipe
Easter Beaver Accessorie block
USB pwr plug
Removable hitch assembly
