Results 1 to 9 of 9
    Feb 2018
    MO
    Default Anti-sway benefits
    Looking at a Baja Ron anti-sway bar. I've already installed Elka Stage ii. What will I FEEL after I get this installed. Thanks. Oh, I ride a 2014 RT...
    Active Member Wrongway's Avatar
    Jul 2017
    Tillsonburg Ontario Canada
    I'll be watching this closely. I have a 2014 RT and is stock form it's a whole lot better than my 2011 was.
    I added the Baja Ron sway bar to the 2011 and it cornered like it was on rails.
    My 2014 doesn't stay as flat as the 2011 with the added sway bar so I'm curious to hear what everyone has to say.
    I won't change the shocks, just the sway bar if I do anything.
    Greg
    2015 RT Limited (White)
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Made a huge difference for me especially because we ride two up most of the time.
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Quote Originally Posted by Wrongway View Post
    Hey, would you get those bugs out of my screen? I sprayed 3 times and there still there.....
    2018 RT Limited "Blondie"
    Faribault, MN
    You will feel less body roll in corners, flatter turns with more authority, it just tracks better as to where you're pointing it. And if you're crazy enough, you'll feel your front tires "roll" occasionally...
    (My wife says that to me, and I have the back of shoulder bruises to prove it!)
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by brendal View Post
    The sway bar fixed two things for me:
    1) when an oncoming bus or semi goes by you, I am no longer pushed around on the road by the wind. Thats not to say I don't feel the air turbulance, just that the bike no longer moves around because of it.
    2) Before the bar, when i took corners, mostly long sweeping corners on the freeway, the bike would "rock" (?) sideways part way through the corner, and I would lose the line I was riding. This no longer happens. Cornering is easy and controlled.
    Ray
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    Default Sway Bar
    Mostly you will feel Damn Glad that you installed it.
    Apr 2017
    North Central Florida
    Quote Originally Posted by OlJim View Post
    Based on the recommendation of about a hundred owners here.......I have ordered one and now have it in hand.
    IF....I get it put on and it does not make a significant difference in the ride stability feel, I figure that each of you hundred people owe me about $2.30 for your share of a bad recommendation !!!!
    Mar 2015
    forrest above Reno, Nv
    Thumbs up +1 on the anti-sway bar
    Brendal,
    The anti-sway bar addition to my made a noticeable difference in handling ( like many hundreds here ) in turning and stability. I also added spring stiffeners. Time after time ryders here have added a better than OEM anti-sway bar and are very pleased with it. To me it was money WELL spent.
    Lew L
    2014 RTS , Circuit Yellow
