Results 1 to 5 of 5
    May 2018
    NJ
    Default Chirping from engine area
    I have a 2011 RSS with around 3300 miles. There is a chirping sound coming from the engine area while underway. I can't seem to duplicate the sound if I'm not moving so it is hard to tell exactly where it is coming from. Any ideas?
    Mar 2008
    Hesston, PA
    Default Just one idea
    Many of the earlier GS & RS had exhaust gasket problems...Many of us replaced the BRP gaskets with Honda gaskets (donut style gasket) Maybe that what your starting to hear failing??? Just an idea...
    Nov 2012
    North Las Vegas, NV
    It could be from the drive belt. Put a small dab of grease on the insde of the belt and see if it goes away. Our 2012 RT would chirp on take off.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    May 2018
    NJ
    Thanks for the replies. Any other suggestions?
    If it only happens when you are moving. Goes faster as speed increases. I'd say the drive belt is the problem. If the belt is tracking correctly. I'd try the grease solution. Be VERY Sparing with the grease! You can always put more on. It's hard to get too much off.
