Results 1 to 6 of 6
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Default Drive belt all the way to inside
    Good evening, my drive belt is all the way to the inside at the rear wheel, I thought it was supposed to be centered. Is this a problem.
    ? Thanks Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Northern Kalifornia
    Default Could be,,,,,
    Supposed to be 1 credit thickness away from the sprocket flange.
    Nov 2015
    Tinley Park, Il
    Thanks, Mike
    Mar 2017
    Salisbury,NC
    Default ??
    did you last back it up??? belt rides better going forward, then check.
    May 2017
    Mesa, Arid-Zone-A
    If you back up, the belt will move to the right, towards the inner flange. You need to roll 8-10 feet forward to see where it usually rides.....
    Semper Fi
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by canamjhb View Post
    Thanks, I'll check it tomorrow
