Results 1 to 17 of 17
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Default Bike lifting options
    Good evening again, we had quite a bit of rain today so I playing with the bike. When lifting her do you have to stay on the front to back metal beam and stay away from the exhaust springs? Is the a way to lift only one front tire or only the rear tire? Thanks, Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Northern Kalifornia
    Default What....
    What are you using to lift the spyder and what is it that you want to lift the trike for?
    Nov 2015
    Tinley Park, Il
    My craftsman mc jack. I was cking out what I need to do/have to do my 1st oil change and remove the rear brakes to clean them to stop the squealing. Thanks Mike
    Oct 2016
    Faribault, MN
    Make sure your rearmost lifting arm is where the angled support bars intersect the main center channel, that adds a few extra inches of width and balance. Usually as I slide it under the bike the rearmost lifting arm is right under my Drivers footboard mount. LIke this
    My HF 1500 lb MC/ATV Jack lifting arms almost reach the outer tubes under the bike, but it's very stable fore and aft and laterally. I usually lift the bike above the highest locking point, slip in the jack stands, one under each A Arm right at the inside of the wheel, and one under the rear shock mount, then slowly lower the bike, double checking the jack stands for solid contact points, before completely lowering the jack and starting the oil change.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    The service manual has numerous warnings about never lifting or supporting under the rear shock mount. Lift or support using the frame only.
    2020 RT Limited , Marsala Red
    Oct 2016
    Faribault, MN
    UH oh, I've had my RTL up on jackstands dozens of times doing oil changes, removing the whole rear trunk assembly even, doing many oil and filter changes, removed the Frunk, and more with the rear always supported under the rear shock mount. I have even mounted the bike using a step stool whilst up on the jackstands and with the 1500lb ATV Jack in place using it's safety locking bar on the highest setting.
    And to clarify, I don't lift it using the shock mount, I lift it under the main frame as depicted in the photo above. Once lifted I use my basic 3 ton jackstands that have the rubberized top caps. YMMV.
    I think the manual also says to not do ANY modifications, so I guess I should de farkle my Spyder just to be safe eh?
    Safe Rides,
    IBA 70020
    Default Depends...
    I have this Motorcyle lift from Craftsman and works well but for a full lift of the spyder. A regular floor jack will work for the individual lifts....
    ​2012 RS sm5
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Default Individual lift?
    What do you mean by individual lift? Like lifting the fronnt only or the rear only to do a rear tire? Thanks a newbie
    Nov 2012
    Pueblo Colorado
    Default Like Chupaca says... regular floor jack works to lift one wheel at a time
    I usually put a 6 X 6 inch square of plywood on the jack swivel to bridge the front A-Arm struts, and use a piece of old tire tread rubber to grip and cushion the main frame channel.
    Make sure you block or anchor the corners with jack stands if you're lifting high or planning on getting under it!!
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by wingit3611 View Post
    Yes, if I want to lift only one front or just the rear tire
    Idaho
    Quote Originally Posted by Jetfixer View Post
    Actually the manual has what appears to be conflicting instructions. When you are lifting the bike to check belt tension then lift by the frame only. This is to allow the swing arm to drop to its lowest position. For other lifts you can use a jack under the rear shock absorber. One instruction says to make sure the jack cups the rear shock mount but the others just say to put the jack underneath the shock.
    2014 Copper RTS
    Nov 2015
    Tinley Park, Il
    Thanks, for all the replies. I actually made a couple of things to help get her up with the jack in underneath the drivers footrest. I will send pics. Yes I want to be able to lift either one the front wheels or the rear by itself instead of lifting the the whole bike if I can.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by wmh9680 View Post
    The bike needs to be level when draining the oil I believe.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    <br>
    2014 RTL Platinum
    Idaho
    For that a floor jack works best. Use the m/c ATV jack to lift the entire bike.
    2014 Copper RTS
    Nov 2015
    Tinley Park, Il
    Thanks, I've got her up in the air rolling all around under her famiarizing my self with where everything is and how to get to anything.
    Dec 2016
    Default Front jacking
    The manual doesn't say we're to place the floor jack to Jack up the front to put kickstand under shocks.
