Results 1 to 4 of 4
    Active Member Nokesy's Avatar
    Mar 2017
    Newmarket
    Default Rear left fender support broke
    Anyone have the rear left support for the fender break? Mine broke at the fender itself just where the support bends cracked and broke on a bump
    If so is there a recall on these?
    Done all of Canada except NWT and parts of Australia, New Zealand and areas of Europe
    Dec 2009
    West Oz
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    Not a recall, some owners have managed to get theirs replaced outside of warranty but others (like me) have not. Seems to be at the whim of whoever picks up the phone at BRP.
    Depending on where they have cracked then they can normally be welded back up and at the same time strengthened - normally by adding a rod behind and some triangular bracing at the ends
    Or alternatively dump the rear fender and go for one of the two options shown in that other thread - that's what I did:-)
    There is a lot of vibration at both the rear fender and those supports which is why they fail.
    Very Active Member Vader's Avatar
    Hudson Valley
    Default I feel your pain..
    Just went through a similar issue with support failure on both sides. And being my GS is no longer under warranty, BRP will do nothing to correct the issue. Even though it's a documented issue. So I bit the bullet, spent the $245.94, and ordered the Sport Rear Fender off of eBay. Instal was pretty easy, and it looks pretty awesome.
    IT IS, WHAT IT IS...
