Originally Posted by stetsr
Turn on key hold in the mode button and start the bike.
NOT necessary to hold it in.
As soon as the dash fully lights up (about 4 seconds after key ON), push the mode button ONCE.
Start as usual.
Originally Posted by CA-SPYDR
You can press it even if the text is not yet on your screen and it will let you immediately turn on the engine!
Only on models from 16, 17 and 18!
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
My complaint?
I can't afford to buy all of the ones that I want!
My complaint?
Would you be in the "color of the day" mode, or a sampling of the various models available??
Earlier years also if you restart within about 3 to 5 minutes of shutting down!
2014 Copper RTS
Guess you never drove a Harley
AJ
Originally Posted by gerald37
The one thing I do not like is when you first start it and put it into gear the bang noise it makes.
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
AJ
I have had 17 Harley's over the 63 years. None of them made this much noise.
2021 RT Limited
Asphalt Grey
Lamonster RT phone mount
Sena SMH-10
Lamonster Belt Tensioner w/ larger roller
Spyderpops Missing Belt Guard
Garmin's GPS
Originally Posted by UtahPete
That's weird ... you should be deaf by now ....
It is not the motor noise I complained about it was the bang when put in gear. My hearing is fine.
2021 RT Limited
Asphalt Grey
Sena SMH-10
Garmin's GPS
2015 RTs se6
I have had my Spyder for about one year now. It is a 2015 RT SE6. When I first got it I had several things I did not like about it but have corrected or learned to accept most everything. The one thing I do not like is when you first start it and put it into gear the bang noise it makes. I know it does not hurt anything but it is annoying. I have learned to shift it without any noise and real smooth. You do have to pay attention when shifting. When I first got it I hated when you turned the key on and had to wait to push the mode button to start. I have got use to that so I know when I walk up to it I just turn the switch on and by the time I am in the seat it is ready to start. I was just curious if anyone else felt this way?
that is the same bike we have and yes it is anoing when those things happen Ive better things to do than wait for the bike to wake up.. and yes it shifts with a bang and the beep beep crap is very anoing
You can avoid the beep beep crap: if you forget to set the brake, just turn the key back on, set brake, turn key off again. Works for me!
NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
Retained the old mirrors with TricLed Signals
General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
Riken Raptor HR.........rear tire (at 114,200 miles)
Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
Gear Brake Decelerometer Module
OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
BajaRon Anti-sway Bar
Kumho ECSTA AST rear tire (at 14,200 miles)
TricLed Turn Signals in Mirrors
I just let it beep for 20 seconds until it shuts off. I'd rather do that and be able to push it around in the garage without having to go through the rigamarole of releasing the brake.
2014 Copper RTS
Are you sure you have to go through a rigmarole, Idaho?
On my 16 F3, in my garage, I park in neutral and apply the park brake. If I want to move it around, I turn the key on, immediately press the park brake release button and then turn the key off again. Only takes 3 seconds. Are the RTs different?
Pete
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
Originally Posted by Don'tPanic
I actually like it when it makes a solid "clunk" when you shift it into first. It's like you're doing something very mechanical and important. I usually follow it up with a grin
I thought I was the only one.....!!
2016 F3 Limited in Pearl White-LaMonster GPS mount, LED fog lights, BajaRon anti-sway bar, Doc Humphrey's vibration dampener
2013 Harley Davidson Softail Breakout CVO/ 110ci of potato-potato goodness
2016 Ducati Xdiavel/ A street demon with a belt and forward controls
Great Idea turning on before you get on
Some days the threshold for what I consider a rigamarole is pretty darn low!!!
2014 Copper RTS
Wait mode
Originally Posted by akspyderman
The wait/mode problem got solved with the 2017's--they tell me.
I am not going to worry about the clunk when they shift into gear. They (as in all motorcycles) do that.
The 17s and 18s still have the 10 second or so delay time before you can start them.
Originally Posted by Red RT-S
On newer Spyders you can press the mode button almost immediately after turning the key and it will start.
Not my 17 F3T.
They must have introduced that in the 17 & 18 then Gary.....my 16F3-L lets you turn on the ignition, hit the mode button and start immediately. I wonder why
Pete
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
I was referring to Paladin.
2014 RTL Platinum
