Results 1 to 5 of 5
    Active Member lois35's Avatar
    Sep 2015
    SC
    Default Tires for Spyder RT pulling a camper.
    What are the best tires that you can get for the spyder rt 2015 which is pulling a camper. Want good traction. Any suggestions.
    Lois
    Active Member wd8ajj's Avatar
    Jul 2014
    Las Cruces NM
    There are millions of comments on the board about tires good and bad. Search the board about tires to get the few 1000 out there. You will find much help on the boards.
    Sep 2014
    USA
    I think you will be fine whatever you use.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by lois35 View Post
    Lois
    Any of the tires will give you good traction, some better than others. Generally, those with the better traction have shorter useful lives.
    Don't exceed the tongue weight and overall tow weight limits in your handbook, allow for longer stopping distances and you're good to go.
    2014 RTL Platinum
    Jun 2014
    ny
    Since any car tire will have a higher weight load capacity just find an all season tire that you like, i put vredstein
    on the front & kumho on the rear and tow a mini trailer
