Results 1 to 14 of 14
Thread: TRICLED Fender
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    Default TRICLED Fender
    Finally got around to replacing the fender reflectors with the TRICLED led fender lights. IMO this is a simple yet very effective safety farkle. Can't have to many lights. TRICLEDs instructions are well written. Completed this install while
    drinking coffee in about 1.5 hours if your are in a hurry I believe you could cut that time some.
    Active Member BernardD's Avatar
    Mar 2017
    Geneva, Switzerland
    Well done! And it is a good choice.
    Ride safe!
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by Chasinsparks View Post
    Do you have any pics of the wiring? I'm torn between this one and the one from Lamonster. Lamonster has the plug and play OEM style harness, and Tricled has the actual reflectors plus lights in them, but i'm worried the Tricled wiring isn't as easy.
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    I had put them on my ST. The wiring is easy as it just taps into the lights at the front of the fender (assuming you don't want them to blink or anything; I didn't.)
    However, the taps resulted in the top of the fender not fitting as well as I would like it to. I took it apart again and soldered the connections right into the BRP wires, along with liquid electrical tape and shrink wrap tubing around the splices. Now the top of the fender fits the way it's supposed to.
    Now I just hope Tricled can come up with something for the 2019 models.
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by Trbayth View Post
    Thanks, I think you just made up my mind for me.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Aug 2018
    Thousand Islands
    I would opt for turn signal as well it makes a huge difference, i tested riding behind a spyder with and whithout, but at minium just having the led for the fender its a great safety upgrade.
    2015 Canam Spyder F3-S SE6
    Detachable Passenger backrest #219400703
    Gauge Spoiler #219400531
    Blue Ridge Windshield #219400746
    Hood stripes decal kit #219400711
    F3 Idler Pulley #219800431 / Lamonster roller upgrade
    Bajaron SwayBar
    Elka Stage 2 rear shock
    Arc LED fog lights
    Lamonster F3 bar clamp with Quad-lock phone mount
    Foam Hand Grip Covers
    Tufskinz Peel & Stick Tank Protector Pad (Glossy doomed carbon)
    Bossier LoUiSiAna
    Quote Originally Posted by donhy View Post
    +1 with blinker option find mine quite handy if I fail to cancel & looking like the for miles down the road with blinker on & not changing lanes, or turning also feel they help when I tow my utility trailer & my tail blinkers may be ubstructed
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very nice. I am thinking if we keep our current models, both should have some more front lighting. We are starting to go on "dusk" rides, and I like to be seen.
    Jul 2016
    Woodbine, Maryland
    i do not have any pics as this was about a year ago. This install is super easy including the wiring.
    To be continued....
    Jul 2016
    Woodbine, Maryland
    Really makes a big difference, with the LED bump skid, fender and a arm lights Ray Charles can see me coming down the road.
    To be continued....
    Bossier LoUiSiAna
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Sep 2017
    Durham,Maine
    Love the looks of that fender, wish my 2012 had them!!
    2012 RTL , Pearl
    Active Member LongIsland's Avatar
    Dec 2018
    Long Island
    Mikey, you can add lights to your fender as well. You can add LED's to the channel on the fender and change the side and rear fender reflectors to lighted ones. TricLed and Custom Dynamics should sell them.
