Results 1 to 25 of 25
Thread: Voltage Meter
    Jul 2017
    Woodbine, Iowa
    Default Voltage Meter
    What type and where is a good place place to purchase a volt meter for a Spyder RT?
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Bossier LoUiSiAna
    Options
    12V-24V Car Motorcycle Blue LED DC Digital Display Voltmeter Waterproof Meter https://rover.ebay.com/rover/0/0/0?m...2F351884215509
    https://rover.ebay.com/rover/0/0/0?m...2F262690106374
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    Options
    I believe that one will be far too small. You need a 50mm, or 2" one. This is the one I put on my bike, although not the same seller:
    https://www.ebay.com/itm/2-52mm-Digi...LH_TitleDesc=0
    Ray
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Apr 2017
    North Central Florida
    Whatever you get it NEEDS to be digital.
    Colored lights by themselves are useless.
    And most analog gauges won't move the needle enough to get your attention; a drop of .5 volts can be SIGNIFICANT.
    Jul 2017
    Woodbine, Iowa
    Quote Originally Posted by bcer960 View Post
    Ray
    That is the one I just ordered. Thanks
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Jul 2018
    Fountain Hills,AZ
    Where did you install it? What did you tap into? Thanx been looking for one...
    Active Member kamper's Avatar
    Apr 2016
    Elkton South Dakota
    I also have the one from ebay. I put it in the old temp guage spot. It is nice to know how voltage is doing since just a little voltage drop can leave you sitting.
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by wilpir View Post
    I put the voltmeter on the right and the clock on the left. I used the power that was there for the other gauges to power them.
    ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Jul 2018
    Fountain Hills,AZ
    Quote Originally Posted by kamper View Post
    Don't you need a temperature gauge? Sorry I'm a newbie...
    Jul 2016
    Kamloops B.C.
    If you remove BOTH the gas gauge and temp gauge, they will appear on your bash, digitally.
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Jul 2018
    Fountain Hills,AZ
    Really? even on a 2012 RT? Did not know that, but you have to remove both?
    Jul 2016
    Kamloops B.C.
    That is correct.
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Apr 2018
    Corpus Christi Texas
    Quote Originally Posted by gerald37 View Post
    Jul 2018
    Fountain Hills,AZ
    I was thinking the rocker switch one ..I have 1 empty switch space in my dash just don't want to take a lot of body panels off to wire it..
    Jul 2017
    Ohio
    ray
    What clock did you install?
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Beekeeper67 View Post
    I just quickly looked for one on e-bay, there may be chaeper prices, but this is the clock I bought, and I am very happy with it.
    https://www.horsepowerfreaks.com/-p-...RoCVhUQAvD_BwE
    Ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Jul 2017
    Ohio
    Ray
    Ray,
    Thanks for the info!
    Gary
    Jul 2016
    Kamloops B.C.
    Anytime Gary.
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Bossier LoUiSiAna
    Found something related, yes requires app & wifi smart device.
    http://products.batterytender.com/Ac...Y-MONITOR.html
    Does not say much about heat protection on motorcycles, should be easier than mounting a volt meter in dash
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    I installed this one on my 2011 RT on the right side after removing the original water temp gage. I also installed their digital water temp gage where the old fuel gage was. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Jan 2019
    Walla Walla, Washington
    Hi, I installed Red LED Intellitronix 9015R gauge, back in 2012 I believe, along with a Intellitronix 9014R red digital Oil pressure gauge in the dash next to the cluster on opposite sides . Intellitronix has a bright red display which is dimmable. I have tried others, this display is readable in bright sun light.
    The DVM voltmeter I found is accurate to .1 volts and usually displays between 13.8 to 14.1 during driving dependent upon lights that are on and brake lights. The accuracy of mine I verified with my DVM fluke and bench DVM which is in calibration.
    The GS & RS Spyders I believe the magneto is 750 watt while the RT is slightly larger capacity, both are controlled by a shunt regulator which clamps the voltage to about 14.1 on my GS.
    eBay and JC Whitney I know are a couple of sources..
    Ps the motor at idle above 13.0 volts. Yes, when you turn on the key after the Spyder has been parked for several days with no battery maintenance charger connected, it will probably be about 12.3 to 12.5 .
    Jan 2021
    Descanso, CA
    OZZ3 -- Did you install the S8434 oil pressure sender the 9014R gauge came with? If so what adapters did you use? Thanks.
    Mar 2013
    Marion, Arkansas
    OZZ3 hasn't been to Spyderlovers since June, 2020, so you may not get a reply.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Jan 2021
    Descanso, CA
    Thanks. I noticed after I posted his engine wasn't my 1330cc. The service manual describes the test port which I think an oil sender can be threaded into and there seems to be enough room for the sender itself so no remote via hose needed.
    May 2018
    millsboro,delaware
    I got a rocker switch/usb port/voltmeter off amazon for 14$,just search it the way I said it.I put it in the unused slot where all the rockers are on my 17rt,yours may be different.Holds up fine in the rain too.
    : 2017 RTL ORBITAL BLUE
