Results 1 to 11 of 11
    Dec 2015
    Oakley Utah
    Default Roadster Electronic Command Center & Infotainment Center
    I've had my RTL for a few years and 17k miles now, and I thought I'd dig into the infotainment system a little more to better understand how to get the most out it.
    I've read the quick reference booklet through from beginning to end several times and I've read the relevant sections of the Owner's Guide. I'm left with these unanswered questions;
    1. What is the 'Trailer Mode' and how do I access that? It's not on any of the menus that I can find and no explanation in the documentation.
    2. Why is there a setting for the date? How is that used by the infotainment system? I've been operating with it set at the default of '0' until today and it doesn't seem to affect anything.
    3. Is there a document anywhere that goes through every menu item, what it is for, how and when to use it? The two guides I mentioned above are very sketchy in what they talk about and what they don't.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    There was an earlier thread that talked about disabling the clock. I could find no such feature, so if there is one please tell me where to find it. I'd like to eliminate as much useless clutter as possible from the dash. Thanks.
    2014 RTL Platinum
    RE: Trailer mode--discontinued with the 998's. You don't have one. The 1330's have enough torque that you don't need it.
    Dec 2015
    Oakley Utah
    RE: Trailer mode--discontinued with the 1330's. You don't have one. The 1330's have enough torque that you don't need it.
    Okay, so that one is a misprint. Thank you for clearing that up.
    2014 RTL Platinum
    Jul 2011
    Mitchell, Ontario, Canada
    Don't know. I have never found it did anything.
    The Command Center pamphlet is the closest I have seen to that.
    4. What is the external speaker setting?
    You can turn the external speakers off if you have wired or wireless headsets. I always turned my volume to low so I could switch back and forth. There is an echo if you don't.
    5. What is the headset mode setting?
    6. What is the headset front setting?
    Both of these are for the wired headsets only. If you don't have them just ignore those settings. It's like the passenger volume control. Only works for wired headsets.
    2018 F3 LIMITED
    Dec 2015
    Oakley Utah
    Okay, thanks. That's very helpful.
    Just to clarify, on #4 External speakers; this is a misnomer because there are no 'internal speakers', right? It's just THE OEM speakers?
    2014 RTL Platinum
    Oct 2016
    Faribault, MN
    Yes, unless you paid the extra fee for the BRP surgically implanted speakers in your inner ear.......
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jul 2011
    External speakers and helmet headset(s). Not a misnomer. Just a differentiator.
    2018 F3 LIMITED
    BRP does a lot of copy/paste. Not a lot of proofreading going on-IMO.
    Sep 2012
    Stetson, Maine
    I believe the date setting is for the computer, for when fault occurs, I believe it is for time/date stamp. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Northern Kalifornia
    Same way they put their products together too.
