Page 1 of 4 1234 LastLast
Results 1 to 25 of 76
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default How to view the clock??
    So i figured out how to set the clock, but cant figure out how to view it. The top right hand corner of the screen seems like the logical place, but this only shows how long the bike has been running. I am sure it is something simple i am overlooking
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Boerne, TX
    Hi, it looks like you have a new RT. It is help to all if you list the model and year of your Spyder in your signature. I never had your problem with my clock but I would bet the owners manual will solve your problem. Good riding.
    Jun 2018
    HAYMARKET,VA
    Test for signature.
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    Dec 2015
    Oakley Utah
    Quote Originally Posted by FINFAN3DP View Post
    Top right is where I find my clock. It's not reliable.
    2014 RTL Platinum
    Apr 2014
    Beloit Kansas
    my 2014 clock was grim alright, but my 2017 is actually correct, and I was really surprised.
    For me the read out (top right) is so small as to be unreadable , so I got a high dollar ($15) Casio Easy read
    wristwatch, large bold dial and face, water resistant, black case and neoprene strap. Works PERFECT strapped just inside
    of the left switch pod. the quickest glance reveals the time
    Bossier LoUiSiAna
    Ya your over looking alright LOOSE THE WATCH
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    the clock on my 17 is small, and I found it hard to see quickly when i was driving. It also does not keep time. It's gained 9 mins since april. I removed the gas and temp guages and replaced them with a clock on the left side and a volt meter on the right.
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Boerne, TX
    Test for signature.
    Ya nailed it!
    Aug 2013
    Northern California
    Default Fixed it!
    I fixed my clock on both the RT and the F3. They both just read "NOW"! They are always spot on completely accurate.......and when I am ryding a Spyder......I don't care what time it is!
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Pirate looks at -- View Post
    So if I do that, you can't leave on a ride with out me in Sept, cause according to my bike, I won't be late
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    The best way to view the clock: pick up your arm, and take a peek at your watch!
    Although the clocks on the 2018 models ARE VERY ACCURATE!
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    Quote Originally Posted by 4 MARIE View Post
    That sounds like a great idea. I don't care for digital clocks anyway, and those casios are pretty cheap and would work fine.
    2010 RT SE5 , Black
    Mar 2015
    forrest above Reno, Nv
    Thumbs up analog clock
    I added a Formotion analog clock to a JT style dash mount. Easy to read at a glance with out taking my eyes off the road. OEM clock is useless.
    Lew L
    2014 RTS , Circuit Yellow
    Aug 2013
    Northern California
    Default Oh No
    Quote Originally Posted by bcer960 View Post
    Ray....nothing starts until you and Tracey arrive!
    Jul 2016
    Kamloops B.C.
    Well this year we're bringing friends, and we're going to hit 9 states before we get there. So, (hopefully not) but we may be late.......
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Aug 2013
    Northern California
    Can't wait. We have a beautiful ryde planned for ya!
    Apr 2017
    North Central Florida
    That works out to about 5.4 seconds a day.
    Not hardly something to justify calling it "unreliable" or non-functional.
    Jul 2016
    Kamloops B.C.
    At least it's going fast, not slow. So if I did rely on it, I would always be early
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Mar 2015
    Default Rather be early.
    For many years I lived by the following: " If your early-- you're on time----If your on time you're late------ and if you're late-- you're fired." It has served me very well.
    Lew L
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Lew L View Post
    Lew L
    well said
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Jun 2018
    HAYMARKET,VA
    Angry
    So another words, no one knows how to get the clock to show up.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Bossier LoUiSiAna
    Sorry & Joking aside its all in the settings, per my 13 it's alway on & just hard to see. Mine can set time,12or24hr format that's it. You might have a enabled or disabled option under the settings(2nd option down in menu list) I do for the DIGITAL RPM & radio not the clock. But they appear in other locations Can say I rely on the visible one on the GPS more often, if I'm looking
    Dec 2015
    Oakley Utah
    I think the clock is next to the equally impossible to read ambient air temp gauge.
    2014 RTL Platinum
    Jul 2016
    Kamloops B.C.
    Although I bought my 17 new with zero Kms on it, the clock was always there. I did not know you could turn it off. Sorry.
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Apr 2017
    I don't think you understand the situation.
    I think EVERYBODY else sees it......and doesn't know how to make it NOT visible......and thus has no need to know "how to make it show up".
    On my '17 it is in the top bar above the main display but is very small......along with the temperature.
