Thanks Thanks:  39
Likes Likes:  47
Results 1 to 21 of 21
    Jul 2015
    Dorr, michigan
    Default Things I love about my spyder
    After all the negative things I have read about Spyders, I thought I would take the time to post my top 20 things that I like about my 2015 RTL, and why I like them.
    The TOP reason I love it is it is just a riot to ride!
    1. Three wheels. No longer worry about falling over, never have to put my feet down at stop light.
    2. Frunk. Much more storage on my spyder than I was accustomed to on a two wheeler.
    3. Handling. Once you get the hang of it, the spyder handles like a very nimble sports car.
    4. Smoothness of ride. To give you an idea of smoothness, the pedometer my wife wore on the Venture Royale would register thousands of steps per ride, on the rear of the Spyder she gets less than 100 steps per ride.
    5. 1330 Power. The power of the 1330, although not a barn burner, is more than enough to tow my camper anywhere I chose to go without being a traffic hazard because I cant reach the posted speed.
    6. Dependability. If you look at my signature you will see the states we have had the Spyder to in just the three short years we have had it. We head out for 2 weeks every year towing the camper, and very seldom put on less than 5000 miles per trip. We have never been let down.
    7. Parking brake. I love being able to get off the bike on hot blacktop and not worrying about if the bike will fall over because of a kickstand sinking into the hot blacktop, while I am away from it. Find a spot, touch the switch, and go.
    8. The adjustable windshield. I use this on every ride for air flow, rain, blocking air, and as of yet at 31,000 miles I have had no problems with it.
    9. Air ride adjusting and adjustable on the fly.. The auto adjusting air ride is an awesome feature. The Venture Royale had to be shut off and put up on its center stand to adjust the air ride. When fully loaded for a trip, this required two people to try to get it on the center stand and was not always a successful operation without unloading some of the things packed on the bike. Yes my compressor failed at about 25,000 miles, and I had a leaking air hose. This was all replaced free of charge ans is quieter than the original compressor ever was.
    10. electronic shift transmission. I still have all the control of up and down shifting as the road requires, without having to pull in a clutch.
    11. Tire replacement cost. I replaced the tires with car tires at a MUCH reduced cost. The Venture Royale was over $300.00 for a rear tire change. I replaced all the tires on the Spyder for less than that.
    13. The nanny. There are times I would like to doe a few things that the nanny blocks (still a little hot dog left in me). However when towing the camper down a hill and water running over the road at the bottom blocked from my view by the truck in front of me, I hit the water and hydroplaned, the rear got loose, the nanny kicked in, straightened it out, and kept us straight on the road. All of this happened before I could have responded other than letting off the throttle.
    14. A true reverse. No more pushing a bike and trailer backwards to back out of a parking space. No more unhooking the camper and pushing it backwards by hand to get into the camping spot. I back in, unhook, and set up with a smile.
    15. Fuel injection. No more fussing with a choke to start on the cold mornings, no more noticing a drop in performance on those hi elevation rides in the mountains.
    16. A power outlet in the truck to keep the phones charged as we ride. Allows me to share our location with the kids as we ride when we are on a long trip. They know where we are at all times, and if something were to happen would know our exact location.
    17. A true alternator for electrical power. With the 1991 Venture Royale I was afraid to run heated clothing along with the lights that I had on the bike, the charging system was notoriously week. Now I run heated clothing with both me and my wife with no problems.
    18. Front and rear speakers. Although we listen to most music on the headsets, it is nice to be able to have the rear boosted so my wife can hear when we are running with the speakers.
    19. Fuel range. I have never had a bike that I could consistently get 200 miles per tank on.
    20. low required maintenance. No more changing oil ever 3,000 miles, spark plugs every year, having valves adjusted, having carbs cleaned, having carbs diaphragms replaced, and replacing front fork seals.
    This does not mean that there is not room for improvement on several items, and I see that some of these things were improved in the 2017 and 2018 models. But just as every other motorcycle out there improves each year that it is manufactured, I think the Spyder will too.
    GREAT job designing a fun machine BRP, my hats off to you!
    2015 RTL
    Consumer Advocate akspyderman's Avatar
    Chugiak, Alaska
    A great idea to post the positive things about the .
    Your list is so complete that, at the moment, I cannot even come up with anything to add.
    Your comparison with the Venture is also right on. I was an early Venture owner. (1980's). Back when they were in the $4K range.
    Currently Owned: 2011 RT A&C SE5 (magnesium), 2014 RTS-SE6 (yellow), 2015 Vulcan 900 LTD
    Previously : 2008 GS-SM5 (silver), 2009 RS-SE5 (red), 2010 RT-S Premier Editon #474 (black) Pictures of 2008 and 2009 Spyders are in Alaska Albums 2009 and 2010.
    5 Spyders, 9 years, 139,000 miles, 5 Spyder miles per post.
    Faribault, MN
    +1, AND I have a '13 with the V-twin, and I still agree with all the positives. Though they get less mileage, my tank can outlast my need to get off the bike and stretch anyhow.
    But, when I need to I can comfortably stand up and stretch on the Spyder's floorboards while moving, I've done it as fast as the 70 MPH range and still felt solid as far as the ride.
    Safe Rides, David and Sharon Goebel
    2013 RT Limited,
    Akrapovic Sport Silencer
    2014 right side grill and block-off plate
    Sena SM-10 w/ MC Dave cable and SMH-10's
    TricLED's Ultimate Safety Bundle Plus, Wide Vu Mirrors, Organizers,
    Multi Mount Dash Mount, Euro Horn,
    LED Head/Foglights
    PPA Widow 15 Wheels, Lamonster Wheel Balancers
    Squared Away
    Laser Aligned,
    Baja Ron's Bar and Links
    SC's HMT Tail/Turn light, BRP Plate frame and Swing Arm End Caps
    Magic Mirrors (Tether-free)
    IBA
    70020
    Default Very Nice....
    Though I have less on the RS I do agree that above all it the ryding ...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jul 2015
    Dorr, michigan
    I have a 1989 and a 1991 Venture royale in my garage still, but they don't get ridden now that the Spider moved in.
    My first venture was a 1986 model and at that time I feel that they were the best touring bike on the market. I have put many many miles on the ventures and they never left me stranded, but I think the Spyder was a GREAT upgrade.
    2015 RTL
    Eponymous Member Bob Denman's Avatar
    Grahamsville, NY
    +1,
    Make it a "+2"!
    If my Ass is in the saddle: my head is in the clouds!
    2010 RT A&C...............2014 RT-L...................2018 10th Year RT-L
    ............Gone; but not forgotten!!................... The Latest, and Best!
    Active Member Arion's Avatar
    Feb 2017
    Very nice to read positive comments. We (I and She Who Must Be Obeyed) agree with everything you've said. We haven't logged as many miles or visited as many states on three wheels; however, our most recent road trip was a 2200 mile jaunt from San Antonio to Tucson and Bisbee, AZ, and return over a period of two weeks in early March. We're pleased to say both Spyders performed flawlessly both on the Interstate and Arizona and New Mexico back roads, some in the proverbial Middle of Nowhere. My bride's 998 2012 RT Limited served as the "fuel gauge" for both of us - almost the perfect range between stops to stretch legs and visit the facilities. We were very pleased and had a flawless trip - and we didn't fall over once! Adjust the windscreen, set the cruise control, place feel in a comfortable position and listen to music or chat with one another - thank you Sena 20S.
    The right hand thumbnail is how they look when we're at home and just puddling around. The left thumbnail is how they look packed for a two week tour. Hmmmm, the look the same. Not really though - I do have a dry bag with rain gear strapped to the passenger seat of my black 2015 RT-S but it's hardly noticeable.
    Active Member gerald37's Avatar
    Jul 2017
    Woodbine, Iowa
    Quote Originally Posted by Fatcycledaddy View Post
    Well said. I have a 2015 RT and have had no serious problems. The only thing I had to do was replace the DESS module but also change a lot of things like car tires, sway bar, and centralmatic balance rs which really improved it's handling. I had read so many negative things and problems people have had with their Spyders that I was about to trade mind off. But It has never let me down and I love the way it handles I am glad to hear the goods things.
    2015 RT Roadster
    Perl White
    Show Chrome Driver Beachcomber Floor Boards
    Show Chrome Driver Backrest
    Penstripping
    Lamonster RT Spyder Cuff For Phone
    Sena SMH-10 & SM10 Blue Tooth TransmitterW/ Daves Cable
    Doran Tire Monitoring System
    Magic Mirrors
    Doc's Belt Vibration Damper
    Set of Centramatic Balancers From Lamonster Garage
    Bajaron's Sway Bar
    Gold Drain Plugs
    K&N Air Filter
    Chugiak, Alaska
    Those V4's were very nice. My dealer sold both Wings and Ventures. I test drove both. The Wing was a bit big for me. I felt more comfortable on the Venture. Wish I still had that one.
    Vermont
    I have a 2014RTS-SE6 (my first spyder was a 2012RTS-SE5, traded for it my current spyder).
    The only thing I had troubles with my current Spyder was a D.E.S.S error,( I started a thread " D.E.S.S. KEY CODE AGAIN!!!!!!!!!!!!!! It has 29 pages long.), had it fixed under the warranty. The farkles that I have added to make it my own.
    It has been trouble free after I had the D.E.S.S. module/switch replaced.
    Deanna
    2014RTS-SE6 Cognac I am a Happy Spyder Owner!
    BRP Semi-Rigid Rear Side Cargo Travel Bags
    BRP Glove Box Organizer
    Ron-rnet Laser Alignment
    TRIC-LED Spyderpockets
    STV Black Carbon Fiber Windshield Blackout
    WRAPMYSPYDER.COM Sceptor Kit Reflective Decals-Orange
    BLUEKNIGHT911 (Mike) painted Dashboard+ GPS plug-in
    BRP Half Cover
    WRAPMYSPYDER.COM Air Dam Web Decal Black Reflective
    General Altimax RT 43 Rear tire
    BRP Full cover
    TRIC-LEDS Front Fender Marker Lights & Saddlebag Markers Lights
    Nov 2008
    Canada, Ontario
    Default I've had my 2018 F3L for several weeks, 1650 miles
    and I love everything about it. The only thing mine is missing from your list is the adjustable windscreen.
    Happy rider here
    2018 F3 Limited black, dark
    Member AngryBug's Avatar
    Jul 2018
    Hume, Missouri
    Default Thank you
    Thank you for posting the positive attributes. I've been lurking here since shortly after hubby got me Angry Bug in June. I was getting kind of worried with the issues being posted (especially on those with low mileage). I was afraid after all my insistence for the last three years a Spyder was the bike I wanted that it wasn't going to be dependable. Thrilled so far (2,190 miles since June 16) and over the moon to hear the positives even if I don't have all the extras the RTs have.
    May 2018
    Jenison, MI
    Thumbs up Great post buddy!
    Coming from a string of fast bikes, I was a little skeptical committing to purchase my 2017 RTL, but after doing it in so glad I did. Now my wife can ride in comfort while feeling more safe than ever before.
    Bossier loUiSiAna
    If you don't mind I can add more, obvious & yet easily overlooked items:
    #21: ALL the great other ryders It & this forum has helped me to meet & Ryde with
    #22: The fun Farkels I have enjoyed adding to it & talking about.
    #23: the pleasantly interested people I meet at almost every stop & the ability to share with them how awesome the is.
    Just a thought (& idea for new thread)
    SpyderPop's LED bumpskid
    SmoothSpyder dualmode back rest
    Tricled foam grip covers, Tricrings, FenderZ &brake light strips.
    BRP trailer hitch & 622 trailer (with its own list: Spyderpops Lighted Rear Bumpskid, LineX protection on sides, led trim lighting amber front& red rear, stand& tongue handle)THX Cruzr Joe!
    (pics in album)
    Jul 2018
    Hume, Missouri
    I have so many people come up and say "What kind of bike is that?", "That's so cool!", "I've never seen one of those", etc. Of course, I also get the incredulous "You ride?" since the Midwest seems stuck in a different era as far as what women are "supposed" to do. LOL
    My favorites though are the little squirts who are fascinated and telling mommy or daddy to "look at that bike" and are amazed that it's a grandma that rides it!
    Yes, before I'm asked, I am young for a grandma (45 with seven grandchildren - one 6 yo, three 4 yo, three 1 yo). That's what happens when you have three when you're young and dumb and then remarry a man who has three of his own. We're a regular Brady Bunch!
    Stephanie & Angry Bug
    2017
    F3T SE6 "Angry Bug" adopted June 16, 2018
    Wish list is growing quickly!
    Added PB1 Floorboards before we left the dealership
    Jul 2015
    Dorr, michigan
    Default Thanks
    Thanks for all who posted their positive experiences with their Spyders, I enjoyed reading each one.
    This forum is a GREAT place to go to when you have a problem and finding a solution for it. Sometimes I feel however that the problems and negitivity can scare people who are just considering a Spyder, and make them walk away. After all if all of this negativity is on a site that goes by the name of "spyderlovers" what is it with the Spyder haters?
    Thanks again!!!
    2015 RTL
    Chugiak, Alaska
    x 2
    Very Active Member Flanker's Avatar
    Apr 2013
    Michigan
    SELFIE!!!! Or it didn't happen!
    Good list, OP!
    2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock (too be installed)
    Nov 2015
    Myerstown, Pennsylvania
    Nice post!! with everything! I love ryding my Critter.
    AKA Jud Smales, One Year Spyder Ryder!
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Ultraguard half cover
    Gremlin bell from my son
    Bossier loUiSiAna
    Quote Originally Posted by AngryBug View Post
    (pics in album)
    Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Default Most post bad only
    A lot of people post here when they have problems - which might make one discouraged. There are many others like the OP of this thread who feel the good outweighs the bad just as I do. A lot of manufacturers have numerous problems - I am also on an HD cruiser forum because we have one of those also and they have many many issues.
    Keep riding your Spyder and enjoy the breeze.
    Love my Spyders
    2016 F3L SE6 delivered 7/16/2016
    Lamonster - third peg, key cover; BRP - driver and passenger backrest, half cover, vibration damper; Wolo Bad Boy horn; Wrap My Spyder decals; SpyderPops - foam grips, Brake/run/turn lights, mirror turn signal lights, bump skid; PB1 -Spyder F3 Performance Foot Pegs
    2014 RTS SE6 - Circuit Yellow purchased 3/2/2018 for my daughter to share w/me.
    No more 2 wheels
