Results 1 to 10 of 10
    May 2015
    East Northport
    Default FOBO TIRE PRESSURE SENSSOR
    I have the FOBO ON MY 2015 rt limted the rear sensor will not light up, I change the battery reinstalled after eight seconds held the box on my phone for 5 seconds cleared the menory. does anyone have anything I havn't done. Do they sell just one sensor HELP
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    You can email them at sameer@salutica.com.my. They are very prompt at answering and will give you the necessary steps to try and reactivate the sensor. If it is in warranty they will replace it, if not you can by a single one.
    johnv
    Harrington, Australia
    I have had a similar issue a couple of times, J48, where I have put a new battery in and still nothing. What has worked for me (it may not be your problem though), is to remove the battery and press on the metal clamps holding it in. This seems to seat the battery more tightly, as these “clamps” loosen a bit when you remove and replace batteries.
    HeliBars Handlebars
    Kenda Kanine rear.
    NorCal - Northbay
    Installing the sensor itself on to another vehicle that runs higher pressure than the spyder has worked for some. Leave it on there for a few mins and you should see it on the display on your phone. Once this happens move it back to the bike and if it is still "installed" (configured in the FOBO app for your byke) it should be working again...
    Chuck
    Nov 2014
    TriCities, WA
    I had 2 of them, 1 bike and one car failed to work after a battery change. I tried everything, Sameer agreed to replace but a month had elapsed and so I thought that I would re-try and install them just to double/triple check, WOW both worked. IMO they are a great item and if they do fail Customer service is great. BUT probably there is nothing wrong except God hates you for a few minutes.
    May 2015
    East Northport
    can anyone tell me were the log is on the appt and how to access it
    Nov 2014
    TriCities, WA
    After login, there is a gear in the upper right corner, "Send log" is at the bottom. It goes to their labs. You can pick to send it by email to yourself. I've only done it once and it wasn't much good as it's in metric and stuff that only makes sense to them.
    Jul 2015
    Dorr, michigan
    Quote Originally Posted by J48cruiser View Post
    https://www.walmart.com/ip/Fobo-Xtra...&wl13=&veh=sem
    This is the best price I have found on just one.
    2020 RT Limited , Petrol Blue
    Nov 2014
    TriCities, WA
    Quote Originally Posted by Fatcycledaddy View Post
    This one doesn't work on the bike, it's a FOBO Tire unit, which needs the "blackbox" .
    Apr 2014
    Orchard Park, NY 14127
    Default Battery
    Try another battery change ...
    I was having problem with my 2017f3 and installing new. seems i had to replace one battery. then release from bike as it had at one time registered. then reinstalled. i have since traded rims with a friend for his all black ones as i have a matte black f3 and reinstalled all no problem, although one always seems to need a couple of tries. remember if you take off to adjust air you done need to do anything but put back on... the same wheels.
    to save phone battery i sign out of app when not using..
    love them.
