Results 1 to 17 of 17
    Aug 2017
    Binghamton NY
    Default 2011 RT Limited no Air Box
    I removed the right side panels to install a J & M CB.
    Looked at the top of the engine and notice the air box / scliencer is not there just the air filter.
    Now I know why its makes so much noise when I roll the throttel on.
    I bought it used and the original owner said He had installed a K + M air filter.
    Between the two brothers muffler and the lack of air box it's noisy especially when going up hills.
    The wife says its to loud.
    So is this a common modification to remove the air box and install the K + M air filter?
    Should I look for a used air box to quiet it down?
    Performance loss?
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    This will be an interesting post to watch .....
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Centramatic wheel balancers on the front and rear.
    Rivco dual flag holder
    Tricled mirror turn signal indicators
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lambskin seat cover from Smokey mountain sheepskin.com
    Tricled 360 degree led Headlights
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Spyderpops bumpskid w led light
    Rivco brand footrest
    spydermanexhaust.com exhaust
    had my exhaust installed @ Spyder in the hills.
    Apr 2017
    North Central Florida
    Quote Originally Posted by bigcontender View Post
    Performance loss?
    Air box....yes and stock filter since the K&N might not fit.
    Real muffler.....yes.
    Performance loss......maybe just the opposite.
    But it will SOUND like it has less power.
    Most important thing is: Listen to your wife.....because you will be sorry if you don't.
    May 2018
    Chateauguay, Qc, Canada
    Sage words of advice.
    2011 RT Ltd. , Pearl White
    GOS member (Girls On Spyders) Spyder_Cowgirl's Avatar
    Bowie, Texas
    Question AirBox Removal
    Didn't JT's machine shop make an adapter for an air filter that allowed removal of the air box (up through 2013 model)?
    EDIT: Here is a link to JT's AirBox filter replacement:
    http://spyderstore.com/index.php?route=product/product&path=59_68&product_id=50
    I considered installing on my 2012 RT, but ended up trading it on a 2016 RT.
    Just a thought …. Ann
    __________________________________________________ _
    2016 RT Limited -- "Jubilee" (as in Cherries)
    Guardian Bell (gift from spyderowboy)
    ISCI Dual Flag Mount – Tall Poles
    Lamonster Bottle Holder and Spyder Cuff
    Spyderpops Missing Belt Guard
    Spyderpops Bumpskid
    Spyderpops Rear Run / Brake / Turn LEDs
    Spyderpops Mirror LEDs
    Custom Dynamics HMT Brake
    Spyderpops Keep Out The Trash (KOTT) Grills
    Don't Eat Mud / mudflap
    __________________________________________________ __
    Oct 2016
    Faribault, MN
    Default Wrapped or not?
    And I believe there's a foam pre-filter wrap that helps silence some of that air inlet noise.
    Does yours already have that or is it the bare version
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Aug 2017
    Binghamton NY
    Default 2011 RT air filter
    Wow never thought of a foam pre filter.
    Yup it's just a bare K + N filter.
    Have to look for the foam pre filter.
    Thanks
    Feb 2012
    Spring City,Utah
    I put JT' air box on my 2012 rt when I changed plugs. I also added the pre filter at the same time and have benn happy with it. I did not notice any significant power increase or change in mileage change. I also have not done anything to the exhaust. I ride my RT long distance and noise would make that unpleasant. Ido notice more intake roar under hard acceleration, seems ok just cruising.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    If it keeps your "Best Half" happy: buy the parts, and put the affected systems back to their stock configurations...
    You can probably even buy the parts from someone in here!
    Default Curious...🤔
    Are you saying the top of the OEM airbox was left off...?? if so you should find /buy a replacement and that will fix the noise problem. If it has the JT or Kewl Metal type filter the pre foam will help quite a bit. The exhaust is a choice as there are many out there with different sounds. If you want to eliminate that noise you can find stock pipes quite easily.
    ​2012 RS sm5
    Aug 2017
    Binghamton NY
    Default 2011 TR air box
    No the air box and noise attenuating system is gone, just a bare 6" round air filter / top plate mounted to the top of the engine.
    Very loud roar on acceleration, sounds like a big block Chevy sucking air. Dose not go much faster but it makes a lot of noise.
    And this is when just keeping up with my buddies @ 60 or so in the hills or on ramps.
    Very annoying
    Apr 2017
    Very annoying
    Which is why I never have and never will (knowingly) buy a bike that has had the power train screwed with.
    Too many amateurs out there just tinkering.
    Oct 2016
    Faribault, MN
    Good to know, thanks for sharing.
    Safe Rides,
    IBA 70020
    Oct 2016
    Faribault, MN
    Performance loss?
    The Foam Prefilter is sold through Jt's website, I put the link in my earlier post.
    Safe Rides,
    IBA 70020
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    We have the JT's air filter with the prefilter as well. Noticed a little increase in noise but not much at all. And if it was noisy, my other half would of already had me reinstall the OEM filter contraption.
    Not sure if maybe the prefilter lessens the noise, as ours has always had one. You can order the Prefilter separately, maybe install it and see if the noise lowers to a reasonable level.
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Aug 2017
    Binghamton NY
    Default 2011 Rt Air Box
    Thanks for the pre filter tip.
    I called JT as I'm not sure what size pre filter I need with the K + M filter.
    JT said to check and see what color the top plate is: Blue it's his, if Black (CC metal or something).
    Check filter diameter and get back to him. So I will check these things and order a pre filter.
    I them called the original stating the with the 2 bros exhaust and the lack of air box the bike was very noisy. He did not know where the air filter kit came for but did have the original muffler which he gave me.
    So hopefully by adding the pre filter and original muffler the bike will be much quiter.
    Thanks again for the help.
    Apr 2017
    It is K and ***N*** not M.
Tags for this Thread
