Results 1 to 7 of 7
    Aug 2017
    Coon Rapids, MN
    Default F3S Driver Backrest
    I have 2015 F3S and considering adding a driver backrest. I also tend to ride with a passenger fairly often. My question for the group is does a driver backrest interfere with the passenger sitting position or ride in any way? Thanks for any input.
    Mar 2017
    South Carolina
    The driver backrest makes a huge difference in comfort level for long rides. I have the Lamonster one, great thing about it is that when riding two up it takes a grand total of one second to remove it. If the passenger is small enough, then no problem just leaving it there, still a fair amount of seat room. But I'll remove it anyway, makes the passenger snuggle in a little closer if you know what I mean.
    Linden, CA
    Default The simpel answer is.....
    MAYBE.. it all depends on how big the passenger is.
    Quote Originally Posted by Sbdraz View Post
    Active Member ekfraz's Avatar
    houston,texas
    Default backrest
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    My wife and I have over 20,000 miles riding 2-up on our F-3 & F3S Daytona with a Can-Am driver & passenger backrests installed and we have zero issues. She's a medium size woman(being careful here) and she has no problem with the drivers backrest installed.
    2020 RT Limited , Petrol Blue
    Size of BOTH passengers can have an effect on the comfort level. If we are dealing with large people (you are on your own defining that), a drivers backrest could be a problem for the passenger. No one wants to ride many miles feeling scrunched up.
    We tried two up the first year with over 10K miles. Between my back and hip problems, and other problems which I will not mention, I determined we could no longer travel two up.
    I was able to purchase a second Spyder, and that has solved OUR issues with the two up.
    Active Member Air Wing Guy's Avatar
    Jan 2012
    Ohio
    Default Baker Built Back Rest
    http://bakerbuiltairwings.com/prodde...p?prod=SPYF3BR
    We have one that is easy install and is quick removal if desired.
