Results 1 to 10 of 10
Thread: Brakes Flashing
    Jul 2011
    Vermont
    Default Brakes Flashing
    During a ride this past week-end with other Spyder ryders, i was told my brakes would flash every once in a while. My foot is no where close to the brake. We are just cruising down the highway. Anyone have a answer for this problem before I take to dealer service. Thanks
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Have you installed the bigger brake pedal?
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Bossier LoUiSiAna
    What year & make you got? May have a weak return spring & allows a bump to move pedal enough it activates the light switch, or a build up of road crud & needs cleaning,just a thought.
    Jul 2011
    Vermont
    I have a 2014 Spyder RT Limited
    Jul 2011
    Vermont
    [QUOTE=samewok;1375772]Have you installed the bigger brake pedal?[/QUOTE
    No I have the regular brake pedal.
    Oct 2011
    Kalamazoo, Mi
    Default flashimg brakes
    [QUOTE=Phyllis;1375797]
    Quote Originally Posted by samewok View Post
    Then you need to either replace the original spring; big pain, or add another light spring to help the weak original
    Al
    2018 F3-T
    2018 F3-T , Pearl White
    Jul 2011
    Vermont
    [QUOTE=IGETAROUND;1375799]
    Quote Originally Posted by Phyllis View Post
    Al
    Thanks for the info. Does the larger brake pedal solve this problem
    Active Member jbarrett85's Avatar
    Jun 2018
    Alabama
    Cool
    [QUOTE=Phyllis;1375804]
    Quote Originally Posted by IGETAROUND View Post
    I would think not for a fix, but if the bigger pad was was the issue I would say the extra weight of the bigger pad would possibly push down on the brake causing your light sensor to blink, especially if you hit a bump.
    Then again I could be totally wrong, it has happened occasionally.
    Mar 2013
    We had the same issue on our 14 RTL.
    I fixed it by shaving down the rubber stop on the brake arm. This allowed the arm to move up as the thickness of the stop kept the break arm too close to activation so bumps would cause the activation of the break light.
    An extra spring would also work, but the shave down was easy, free, and worked!
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jul 2011
    Vermont
    Quote Originally Posted by PW2013STL View Post
    Thank you. Will give this a try..Always like to avoid Spyder service.
