Thanks Thanks:  3
Likes Likes:  3
Results 1 to 23 of 23
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default Newbie with Multiple Questions
    Hi everyone. I'm a new Spyder owner! I picked up my 2016 RT Limited on Friday. It had 1325 miles on it, and I got it for $18k.
    1) It has a Garmin Zumo 660 on it, and I noticed that it says i can connect my phone to it, for audio or phone via bluetooth. I was able to connect the phone portion, but i'm unable to connect the audio so i can listen to my SIRIUS app. Is there some trick? I ordered the 3.5mm cord for the trunk, so maybe this won't be necessary? I'm just unsure.
    2) I washed it yesterday, and afterward, when I put it back in the garage and set the brake, the beeping wouldn't stop. But this morning it was fine. Could this be some sensor that got wet?
    3) Speaking of washing, what does everyone use on the windshield? I always blow dry it with my leaf blower, but i still have spots.
    4) I'm a large guy at 387lbs, is there a good setting recommendation for where I should put the adjustable shock? Should i have it entirely on the soft side, or totally on the hard side or somewhere in between. I didn't notice any difference no matter where I set it, but wondering where it should be for my fat a$$.
    I'm sure I will have plenty more questions to ask in the coming days, so thanks in advance! Love this site!
    Apr 2012
    PA
    Quote Originally Posted by FINFAN3DP View Post
    Lamonster sells a bluetooth device that may help. Also Motorcycle dave sells a SENA unit that will help.
    If you shut off the engine with out setting the parking brake, it beeps. Stops after 10-15 seconds.
    Use a good window cleaner with micro fiber cloth on stock W/S.
    My guess is you want it pumped up near max.
    Lots of good people here that can help. Tom
    "I am the guardian of lost souls! I am the powerful, the pleasurable, the indestructible Mushu!"
    2016 F3Limited Intense Red Pearl
    Lamonster LED headlight and fog lights, Custom Dynamics LED fender and saddle bag lights, Can Am hitch, Can Am rider and passenger backrests, Baja Ron sway bar and Lamonster dog bones.
    Eponymous Member Bob Denman's Avatar
    Grahamsville, NY
    on your Limited!
    I'm pretty sure that the "parking brake beep" was just an anomaly that was the result of everything that was going on at the time... I wouldn't worry much about it.
    As regards your weight and the ACS system:
    The ACS is measuring ride height only. It will automatically do what is necessary to keep the ride height constant. You use the suspension buttons in front of you to "fine-tune" what the ride height setting is.
    If you look up at the rear shock on the left-hand side of the bike (About where the bodywork dips down near it); you'll see a strut that hooks between the swingarm, and the rear shock... that is your ride height sensor.
    If my Ass is in the saddle: my head is in the clouds!
    2010 RT A&C...............2014 RT-L...................2018 10th Year RT-L
    ............Gone; but not forgotten!!................... The Latest, and Best!
    Jun 2018
    HAYMARKET,VA
    on your Limited!
    Thanks Bob!
    Jun 2015
    Hampton Roads, VA
    1) I think the music part is MP3's on a memory card. In order to play your phone through the speakers, you can connect to the USB in the trunk, but you may not have control in SIRIUS. Only the iPhones / iPads have full control. Android devices just advance to next song only. There is a trick I did on my 2016 RT-S. This is your model without the GPS. I prefer to use my phone for the GPS and music. On the left side of the bike sip tied to the rear of the gas tank is the cable for your GPS. It has the standard 1/8th headphone jack (female) going to the GPS audio. My bike it was just zip tied with a cover on it, having no GPS. You could put a "Y" adaptor inline (male to two females). Then run a male-to-male (3ft or 6ft) up and out of the rubber cover in the center of your handle bars. But then it's GPS or music. Or just use the phone for GPS.
    2) Possible - was light still flashing on the dash? That would tell you if it thought brake was off. Be sure you set it when engine is running and watch (and feel the peddle drop a bit).
    3) Many choices, I use spray detailer. Lamonster carries some good stuff.
    4) Thats mainly (IMHO) to level the bike - so the only time you will notice anything is at night time. Adjust the level so your headlights are aimed well and not blowing up peoples faces in cars . Then leave there. Many of us haul trailers, ride two-up, etc. and know which level to use to keep bike level.
    Welcome and have fun!
    Grahamsville, NY
    Thanks Bob!
    Glad to help out when I can!
    I used to use those suspension adjustment buttons to fine-tune my lights.... it also affects your headlight aim!
    Active Member Kiry's Avatar
    May 2018
    Seattle
    I use All Kleer, it's designed for plastic windshields, and I think it's priced fine. I got mine on Amazon.
    2017 F3-L Intense red
    Spyderpops Spyclops Light
    TricLED Headlights and Fog lights
    Madstad Windshield
    Phoenix - Wrap My Spyder
    Dec 2015
    Oakley Utah & Hurricane, Utah
    • The speaker on the gps isn't designed for listening to music.
    • You can load music on the gps for it to play via BT through your helmet communicator, but not through the bike's sound system.
    • The audio plug in the trunk is where you can connect your phone to play music; this goes just to the bike's speakers, not your helmet.
    • There is a dongle that can be added to the bike's sound system to provide BT connection capability; it doesn't come built in.
    2014 RTL Magnesium & 2014 RTL Cognac
    Northern Utah in summer; Southern Utah in winter
    Vermont
    or did not happen.
    Deanna
    2014RTS-SE6 Cognac I am a Happy Spyder Owner!
    BRP Semi-Rigid Rear Side Cargo Travel Bags
    BRP Glove Box Organizer
    Ron-rnet Laser Alignment
    TRIC-LED Spyderpockets
    STV Black Carbon Fiber Windshield Blackout
    WRAPMYSPYDER.COM Sceptor Kit Reflective Decals-Orange
    BLUEKNIGHT911 (Mike) painted Dashboard+ GPS plug-in
    BRP Half Cover
    WRAPMYSPYDER.COM Air Dam Web Decal Black Reflective
    General Altimax RT 43 Rear tire
    BRP Full cover
    TRIC-LEDS Front Fender Marker Lights & Saddlebag Markers Lights
    Jun 2018
    HAYMARKET,VA
    How does the gps voice come through the bike's sound system?
    Vermont
    Nice looking spyder! What is going to be your first farkle?
    I have a 2014RTS-SE6 ( cognac), look at "My Albums" for farkle ideas. Also, visit the "Vendors" on the "homepage". For some farkle ideas. They are awesome, excellent customer service.
    My "Dashboard" ( on mine Blueknight911 painted it, I got the idea from his dashboard).
    Deanna
    BRP Half Cover
    BRP Full cover
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by Kiry View Post
    I will order some tonight! Thanks!
    Jun 2018
    HAYMARKET,VA
    Deanna
    Love the Stainless grills by your feet! WOW!
    Faribault, MN
    FinFan3DP, Congratulations and Welcome, NICE color, is that matching your truck in the back ground as well.
    Looks like you got a couple farkles already installed, Cup holder, back rest and pax arm rests. Nice Ryde.
    May it bring you many, many miles of smiles!
    In answer to washing / detailing, I'll put another log on fire for Lamonster's Black Dymond, it wipes bugs right off and helps keep the Spyder clean, good for all surfaces, I use it on my windshield, the painted body, the black plastic bits, and the chrome.
    Safe Rides, David and Sharon Goebel
    2013 RT Limited,
    Akrapovic Sport Silencer
    2014 right side grill and block-off plate
    Sena SM-10 w/ MC Dave cable and SMH-10's
    TricLED's Ultimate Safety Bundle Plus, Wide Vu Mirrors, Organizers,
    Multi Mount Dash Mount, Euro Horn,
    LED Head/Foglights
    PPA Widow 15 Wheels, Lamonster Wheel Balancers
    Squared Away
    Laser Aligned,
    Baja Ron's Bar and Links
    SC's HMT Tail/Turn light, BRP Plate frame and Swing Arm End Caps
    Magic Mirrors (Tether-free)
    IBA
    70020
    Jun 2018
    HAYMARKET,VA
    Yes, it's a 2017 Ford Edge Sport.... My last 5 Edges, have been white. "Good Guys Ride White Horses" is what my Grandfather used to say! I will check out Black Dymond tonight!
    Jun 2018
    HAYMARKET,VA
    Just realized you were talking about the seller's truck in the background. I will have to get a pic of it in my garage so you can see the Edge Sport.
    Vermont
    Sent PM, about the grills.
    Deanna
    BRP Half Cover
    BRP Full cover
    Jun 2018
    HAYMARKET,VA
    36722706_10214804660704225_182670211843883008_o.jpg There is one with my Edge Sport in the same Pearl color.
    2016 RT Limited
    Dec 2015
    The OEM wiring harness for the gps connects to the sound system harness. It should override whatever you are listening to on the speakers.
    Jun 2018
    HAYMARKET,VA
    So theoretically if you can connect the bluetooth from your phone to the gps wouldnt it play your phone through the bikes sound system?
    2016 RT Limited
    Aug 2013
    Northern California
    Have to say that Lamonster's Black Diamond detailing products are the very best you can find. They work on all surfaces and the Black Renew Product will keep all the Black plastics parts on the RT really beautiful, and they really POP next to that Pearl White!
    Dec 2015
    That's not how it works .
