Results 1 to 3 of 3
    Active Member teninospyder's Avatar
    Sep 2014
    tenino, wa
    Default Anybody know if...........
    Looking at the "available" pics of the parts making up the right hand rear storage compartment, it looks as if I can simply remove the bolts holding the inside luggage shell, remove it, and I would be able to see directly into the area where the ACS "Air Release" Solenoid is located. I am trying to gain access so I can disconnect that solenoid and have the system work off of "the air pressure I put in via the schader valve fitting under the seat. Need to clearly see the connector to disconnect it (don't want to damage it).
    Ray & Marci
    Tenino, WA
    2014RTL Cognac
    ALWAYS ride 2 up.
    Invalid Emails
    Oct 2015
    morgantown west virginia
    if it is the same as a 2012 rts just remove the right side panel and it will be just in front of the right saddlebag I believe.
    May 2017
    Mesa, Arid-Zone-A
    One of my riding buddies has a 2015 RTL. The dealer did a quick reprogram so his rear suspension operates manually. The dash switch still operates the air pressure but it increases or decreases pressure the same as using the schader valve. No more automatic leveling.
    Semper Fi
