Results 1 to 15 of 15
    Active Member Buckeye Chuck 54's Avatar
    Jun 2015
    Zanesville Ohio
    Default Side case hinges.
    I posted earlier I had my 2014 RT-S in for service. After getting it back I saw the right front
    side case hinge was broken. Of course they said it was like that when I dropped it off.
    I had planned to buy the side case hinge upgrade from Roadsterrenovations anyway. I'm
    handicapped and when I got them I saw it was a bit more than I could do. I could have
    done the 3 that were not broken, but that last one... So I wrote Steve, he said he would
    do the install, for free! So I arrive at his garage a little past 11 AM this past Friday. It turned out
    that broken hinge was very broken. It didn't help somebody (me) tried to super glue it in place.
    To repair a broken one he took the lid off to access the area easier. First he tried to glue it in place
    properly but it wouldn't have been strong enough. So Steve went to work and drilled 2 small
    holes in the case and ran 2 steel bolts through. Then he made steel brackets that attach to the bolts,
    that attach to the hinge. He even painted the brackets. There was no trial and error, he knew
    just what he needed to do and got the job done. It still took over an hour to complete.
    All the time and parts he still wouldn't take a donation. He believes in his products that smooth out our rydes.
    I think I've made new friends. His wife, Cathy was right there to help whenever Steve needed anything.
    There's a lesson to be learned here. Even though Can Am makes a superior machine, some things aren't.
    These side case hinges are mounted to plastic, pretty flimsy. Easy to break and when they do it can be
    a bear. Think of breaking one an vacation hundreds of miles from home. The only way to close the lid
    is to duct tape it closed. I thought of buying these hinge upgrades earlier but waited until it was too late.
    I'm glad I live relatively close to where Steve runs his business.
    Some farkles are just that, farkles. Something not necessary, but something just wanted. These hinge upgrades
    are not a farkle, they're necessary.
    When the work was done Steve and Cathy even escorted me the 40 miles to get back on I-74
    Great people these Humphries.
    Thank you Doc!
    Buckeye Chuck
    United States
    Thanks, Chuck! We had a great time!!
    Here is a picture of the plastic area the hinge attaches to.
    As you can see, when they molded the case they left voids in the front and back to extend the plastic and make holders for the backing plate. So you have this long piece of plastic with just a little plastic to keep it from breaking. That is what is holding up the lid. Very flimsy. We have yet to have a case hinge break that has the side case upgrades. Here is the link:
    https://www.roadsterrenovations.info/misc-items
    Chuck,
    Glad to hear that Doc got your bike all healthy again!
    Active Member CentralCoastCA's Avatar
    Aug 2012
    Santa Barbara County, CA
    I've been meaning to get those for awhile - thanks for the reminder, just ordered them. The hinge on the left side of the Spyder side case has always been problematic.
    2020 RTL SE6 Asphalt Grey
    2014 RT SE6, Pearl White 57k (2014-2020)
    2008 GS Premier 17k (2012-2014)
    Mar 2015
    forrest above Reno, Nv
    Default Loose hardware???
    This thread got me curious, and I decided to check the hinges on the side cases. All 16 bolts were not tight. Not rattling loose but not " snug ". Don't know if there is a torque spec. for these fasteners BUT it has to be higher than what I found on all the bolts that hold on the side case doors.
    So I tightened them, snugged might be a better term. I wonder if this could be part of the cause of the hinge breakage issue????
    Lew L
    2014 RTS , Circuit Yellow
    Mar 2016
    Willis, Michigan
    Probably a dumb question, but exactly what is the determinant that limits the luggage weight in the side trunks to 15#? Do the hinges contribute, and if so, if I replaced them with your hinges, Steve, could I carry 25# harmlessly? I regularly want to put one 25# bag of kitty litter in each side trunk, and did so just one time, but felt guilty and worried all the way home.
    United States
    Quote Originally Posted by ruralgirl View Post
    Our upgrade are not new "hinges". There is nothing wrong with the hinges. Click on the picture I posted in post #2. The plastic the hinges attaches to is very weak. Not on the lid, but in the case. What our kit does is strengthens the existing hinge setup by using spring steel that makes contact with a solid area.
    This is only part of the solution. We use a "sandwich" setup that integrates the inner and the outer to strengthen the entire joint.
    The backing plate is shimmed and nutted to incorporate the bracket and the plastic on each side to make one solid piece. With the inner spring ability to flex, it allows the plastic to move like it is designed to do. The more flex the harder the spring "pushes back".
    I will tell you how good this design is. It was created in 2015 and I have yet to make one single change in all that time.
    Care should be taken when pressing downward on the lids. That will quickly break them. And as I said, we have yet to get a report of a broken hinge for any RT's that have our kits installed.
    Jun 2015
    Zanesville Ohio
    Default Thanks Bob
    I wrote this thread because I'm aware of the problems RT models have with side case
    hinges, well, not the hinges but the plastic holding them.
    I'm bringing awareness to all that own any RT model, these hinge brackets can fail.
    I know, if one fails it can ruin a vacation or long ryde.
    I hope I can make it to Spyderfest so I can show off some of Doc's work.
    Chuck
    Chuck,
    Mar 2016
    Willis, Michigan
    Quote Originally Posted by Roadster Renovations View Post
    ......Care should be taken when pressing downward on the lids. That will quickly break them. And as I said, we have yet to get a report of a broken hinge for any RT's that have our kits installed.
    Thanks for your post. I shouldn't have said "hinges" as I did read your explanation on your product page and understood that it's the (pictured) brackets. But somewhere I thought there was a brief comment about the kit influencing the overall ability of the trunk to carry weight.
    Dec 2015
    Oakley Utah
    I'm interested in getting these brackets, but would like to know what is involved in installing them? Thanks.
    Update; found the install video on your website. Thanks. https://www.roadsterrenovations.info/how-to-videos
    2014 RTL Platinum
    Pete,
    Order them: Once you get them in place: it's pretty easy to see how they perform their magic!
    I put them on mu 2014, and my 2018...
    (Hint: it's easier to install them on the right side; if you pull the muffler off the bike.)
    Dec 2015
    Oakley Utah
    Pete, Order them: Once you get them in place: it's pretty easy to see how they perform their magic! I put them on mu 2014, and my 2018... (Hint: it's easier to install them on the right side; if you pull the muffler off the bike.)
    I just ordered a set so I'll have a chance to find out for myself. Then, I can order a set for the other RT. The website won't let me order multiple sets at one time, so we'll try one and then see where I go from there.
    I was also considering the spring stiffeners, but I need to first do some research on here. Seems like BajaRon has a stiffener also?
    2014 RTL Platinum
    Yes; he does... I had a set of them, and liked the adjustability.
    May 2012
    North Las Vegas
    I am sure glad the wife and I have them on our bikes.
    USAF MSgt, Retired
    2018 F3 Intense Red
    Squared Away Lasar alignment, TricLED Headlights, Foglights,Safety Bundle with Turn Module, BajaRon Sway Bar,Squared Away Mirror Wedges, Stebel Air Horn, Dash Turn Indicators, TricLED USA Flag
    2018 F3L , Intense Red
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Buckeye Chuck 54 View Post
    Thank you Doc!
    Buckeye Chuck
    I like your Avatar.When I in Argentina if you get a number like that (ascending/descending order) on your bus ticket it was considered good luck.It is called a copicua
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
