Results 1 to 5 of 5
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Default Passenger backrest
    Spyder RTL 2018. I need to remove the passenger backrest. Is someone on this board can explain how? and please I don't need rudes answer like "do a search on this board" which unfortunately happens quit often. Thank you.
    2018 RT Limited "Blondie"
    Mar 2015
    Brockport, NY
    Default I think it’s pretty straight forward
    I believe there are three bolts accessible from rear trunk, that release the seat back.
    Just took mine off to refresh my memory. There are three torx bolts in trunk, and two torx on trunk hinge that you need to loosen that fit in the slotted section at top of seat b
    2014 RT-S Pearl White
    Apr 2018
    Quote Originally Posted by Brentc View Post
    Thanks. I'll start with that..
    Mar 2015
    Brockport, NY
    Default See ipdate
    Quote Originally Posted by mbenazeraf View Post
    I added to my original post for you.
    Apr 2018
    Got it out. Thanks for your help..
