Page 1 of 2 12 LastLast
Results 1 to 25 of 49
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Default Stranded in Orlando
    On a trip - started as a nice way to reconnect with some old friends. Then... the bike stopped running. The starter turns the motor over but there’s either no spark or no fuel. And of course it’s Sunday, so my options are few.
    Does anyone have any easy things to try (limited tools), or a great dealer near Wildwood, FL?
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Mar 2015
    Brockport, NY
    Default Kill switch
    Double check kill switch?
    2014 RT-S Pearl White
    Sep 2014
    United States
    Kill switch on is “unskilled” position, fresh gas in the tank, battery is good.
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    SoFlo
    Being in Wildwood, do not go to RideNow Ocala, you need to use Central Florida Powersports.
    Are you on FB? You might try and message Kenny Butler for ideas, but realize, being Sunday, it is his day off from CFPS.
    Very Active Member spyderCodes's Avatar
    Jan 2016
    PA
    Try the WOT *Wide Open Throttle)
    Ignition ON
    Twist and hold throttle Wide Open
    Crank Engine
    Release Throttle
    Try restarting without opening throttle.
    The Power of Logic.
    Start Thinking.
    SoFlo
    Quote Originally Posted by spyderCodes View Post
    Ignition ON
    Crank Engine
    Release Throttle
    Great idea, forgot about that
    Oct 2016
    Sebring, FL
    Good luck and let us know if it works. Central FL Motor Sports I read has an excellent shop, but getting to Kissimmee from Wildwood, that's a job right there.
    Nov 2016
    Upstate NY
    Default Check fuses in left fuse box
    The left fuse box is on your right when facing front of bike(fuse box closest to thumb shifter). Pay close attention to fuse 6 and 8. They are for ignition coils and fuel pump. Hope that helps.
    2021 Sea to Sky RT , Highland green
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    that's a bit confusing
    the bike, like a person, has one left side and one right side-
    the fuse box is on the left side of the bike, no matter which way you look at the bike
    your left arm is on your left side, no matter which way someone looks at you
    2017 F3, SM6-basic black, plain and simple
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Quote Originally Posted by ofdave View Post
    That's true, but is sometimes forgotten when under pressure.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by Brentc View Post
    Starter turns the motor. OP's original post!
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Active Member RyderJCF's Avatar
    May 2013
    Ocoee, fl
    There’s also Barney’s in Brooksville - MUCH closer than Kissimmee
    ​Jeff
    2012 RT Limited Lava Bronze (aka "The Bronze Beauty")
    Ultimate faux crocodile seat, backrest , and armrests in cognac-/black, Luggage nets, luggage, drink holders, top mirror, shorty antenna, SENA SMH10 headsets and SMR10 dongle, Garmin 665lm, Tri-pouch, Trunk mount flag poles, Custom Dynamics vent covers, Show Crome Luggage Rack, custom mud flap, Full Size Brake Pedal, Tricled mirror turn signals, LED strips on rear of front fenders, custom highway pegs, BakerBuilt Air Wings w/ Uppers
    2012 RT Limited , Lava Bronze
    Apr 2017
    North Central Florida
    Quote Originally Posted by RyderJCF View Post
    Good suggestion. But they are not open on Sunday OR Monday.
    Any chance that the battery is weak ? Might want to charge it for a while to see if that might help......if you can.
    How fresh IS the gas ? If it stopped running real soon after a fill-up, then the quality of the gas would be suspect.
    May 2016
    Florida
    Quote Originally Posted by OverHillAndDale View Post
    Do you have it started? I’m talking with Can Am Ken now. He’s the areas go-to guy for spyders.
    Mar 2015
    Brockport, NY
    Default Why are you yelling
    Quote Originally Posted by jaherbst View Post
    Jack
    To the original poster, I hope your having success in getting underway and I apologize in advance for using your thread to respond below.
    Jack:
    And the need for your punctuation of an exclamation point? I fail to understand how yelling at me for missing something in the original posters comment either helps him or anyone else reading this post.
    This goes right in line with the post Lamont put up a few days ago regarding posters like you Jack. You are often quick to comment on others for something you perceive in a negative way. It does nothing to further the conversations and often keeps people from wanting to take part in any of the conversation.
    If you haven’t already, please add me to your block list, I obviously am not in the caliber of people you wish to correspond with civily.
    Oct 2016
    Sebring, FL
    Yeah Jack, this guy has a problem, someone trying to help and you're screwing around with semantics. I'm sort of a newbie here, but man, you need to get a grip.
    SoFlo
    Guys, get over the punctuation thing. His reply is solid if you notice his quote from someone else he replied to.
    The suggestion about checking the red kill switch. The original topic indicated the engine cranks but would not fire. If the kill switch is in the engine off position, the engine will not crank.
    I hope the guy got it fired up, but the replies asking to be blocked seems silly and overreacting because you are fired up.
    Apr 2017
    Although it would have been MUCH better to state what you did in the sentence above, the comments about posting style are WAY more disruptive.
    Some of you had better be careful ASSuming what the owner will take offense at.
    It might end up being YOU.
    Jul 2017
    sarasota, fl
    why does a simple question regarding a problem have to downgrade into an argument and calling out posters for what amounts to nothing?
    It certainly adds nothing to the thread and provides absolutely no help to the OP.
    Come on people.
    Answer the question without slamming someone else.
    You want to give help or just bitch about something?
    There are many, many of us here who are tired of it.
    Mar 2015
    Brockport, NY
    Default Agreed
    Come on people.
    Mar 2015
    Brockport, NY
    Default FYI, spiders to the rescue screenshot
    This is s screenshot of the Spyders to the rescue info for the Orlando area, if useful. Good luck. 62D60A5E-D31A-4C5A-B0E4-90529C66D9D4.jpg
    Jun 2016
    Harrington, Australia
    Great description, Joel....sometimes you do forget which side is which.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2015
    forrest above Reno, Nv
    Default Fuses???
    Check those fuses carefully. I had a cracked fuse in one of my older cars---- very hard to spot. Also had a chaffed wire on my old 66 mustang -- would blow a fuse when the key was turned. ( finally found it though.)
    Good luck.
    Lew L
    Oh ya: punctuation??? When is speeling the police going to rear it's ugly head.
    2014 RTS , Circuit Yellow
    Sep 2014
    United States
    Lots of great suggestions, none have paid off (gas was a few hours old, fuses were good but I replaced them anyway).
    But it now gets more interesting. I went to start it this morning and it fired right up like nothing had ever happened. I took a chance and rode it to the prison I was visiting (old friend is incarcerated). It behaved perfectly.
    Went to start it again this afternoon and it would crank. I ended up having to tow it back to the hotel because no place near here will accept bikes on Sundays.
    SHort term plan - if it starts in the morning, I’m heading straight back home stopping only for gas but will not shut down the motor. If it won’t crank, I’ll have to have it towed to a dealer, fly home, and try to talk the hotel into letting me park my little trailer somewhere.
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    Nov 2016
    Upstate NY
    Yup, that's interesting. The only thing I can think of is a relay is sticking. That could cause an intermittent problem like that. Now the question is, which relay would it be. You can swap one relay for another. I would pick a relay that is used for something like high beam headlights or suspension and swap it for another and see what happens. Go through all relays until it starts. Hope its that easy. Good luck.
