2011 rss se5. Have bled brakes manually and with BUDS. Brake pressure has and still reads 3600. The pressure will increase slightly when brake pedal is pushed but the low pressure light never comes on. Any thoughts out there?
What DTC's is the bike in question setting? And have you checked wiring diagrams for the affected systems to see if there's any common/shared circuits?
Only active code is C0044. I have an online manual that the wiring diagram is very difficult to read. Trying to find a better one. C0044 = BLS internal pressure sensor failure BLS fuse is good.
