Results 1 to 19 of 19
Thread: Screw HELP!!!
    Active Member ATitus's Avatar
    Jul 2015
    Crown Point, Indiana
    Default Screw HELP!!!
    Has anyone here had issues with a body panel screw the won't come out. I have on that keeps turning but won't tighten or release. Any suggestions on getting it out would be much appreciated.
    Life is GOOD...............
    2015 F3S
    SmoothSpyder backrest
    lidloxs
    Gloryder F3 Logo Lights
    Lamonster mirror relocations and turn signals
    Lamonster fog light kit
    Lamonster Power Plate
    X Grip
    Ram mount
    Mar 2015
    forrest above Reno, Nv
    Thumbs up
    If you can get a pair of needelnose locking pliers on the head of the screw and PULL as you turn saw.
    Good luck---- others here will have great ideas.
    Lew L
    2014 RTS , Circuit Yellow
    Jul 2015
    Quote Originally Posted by Lew L View Post
    Lew L
    Thanks Lew, I've tried needle nose pliers but not locking ones! Great idea!
    2015 F3S
    lidloxs
    X Grip
    Ram mount
    Northern Kalifornia
    Default Which one is it?
    Where is it located on your spyder? I had one the other day and finally got it out. Success depends on which screw it is and it's location.
    Active Member Don'tPanic's Avatar
    Oct 2017
    Pennsylvania
    Default hold the clip
    There's a clip on the other side that came loose and keeps turning. Try holding it in place with pliers as you turn the screw
    Jul 2015
    On the right side of the Spyder as you sit on it. Screw number 2 from the front of the panel.
    2015 F3S
    lidloxs
    X Grip
    Ram mount
    Jul 2015
    Quote Originally Posted by Don'tPanic View Post
    Where this screw is, I have not been able to get my hand behind it to reach the clip. I'll keep trying, thanks!
    2015 F3S
    lidloxs
    X Grip
    Ram mount
    Northern Kalifornia
    Darn, mine was on an RT. If you can get anything behind that spring nut to jam it and stop it from turning. Just about any kind of pressure on it may help. Either pushing or pulling. Take your time and think it out. Don't rush it.
    Jul 2015
    Thank you Sir, I've had the issue for some time, when I get frustrated I walk away. LOL!!!
    2015 F3S
    lidloxs
    X Grip
    Ram mount
    Apr 2017
    North Central Florida
    This problem screw doesn't have a "security" head on it, does it ??
    On the RT there are two on each side that are not MEANT to be unscrewed; they screw into a rubber plug which PULLS out as the final step to get the panel loose.
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    If nothing else works, then the final straw will be drilling out the head. Start with a 1/8" bit and then go to the 1/4" bit. The head of the screw will pop off then.
    Jul 2015
    No sir, it's a removable panel screw, on the F3 the four panel screws have to be unscrewed.
    2015 F3S
    lidloxs
    X Grip
    Ram mount
    Jul 2015
    Quote Originally Posted by bscrive View Post
    Thank you....
    2015 F3S
    lidloxs
    X Grip
    Ram mount
    Apr 2011
    GREENVILLE, SC
    Default HAD 1
    i had 1 on F3.... pulled on the screw, and the 'nut' part came out of the Tuperware behind.... made a dab of apoxy-glue and stuck the 'nut' back in.... haven't had a problem with it since... it's been 3 yrs... PS; do NOT get glue inside the nut on the threads.... bad bad bad....
    good luck....
    Dan P
    SPYD3R
    Jul 2015
    Quote Originally Posted by SPYD3R View Post
    good luck....
    Dan P
    SPYD3R
    Thank you
    2015 F3S
    lidloxs
    X Grip
    Ram mount
    Jun 2010
    Las Vegas
    The two forward screws on the side panels go into a brass piece that is prone to coming out if you use too much force, like power tools. Why they didn't use clips like they have on the rear two screws is beyond me. Joe has repaired several of these, just did one on Tuesday, but he’s teaching today and won’t be looking at the site but I’ll tell him to look for this thread so he can tell you the repair method he uses.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2015
    Thank you very much!!
    2015 F3S
    lidloxs
    X Grip
    Ram mount
    Jul 2010
    Las Vegas, NV
    Default My fix
    Remove the other 3 bolts. The problem one will probably be still attached to the plastic panel with the brass nut on it. Use a soft jaw pliers to hold it while you unscrew the bolt. The brass nut is slightly tapered. I drill the hole it came out of slightly with a 1/4” bit. Undo the 2 10 mm bolts on the plastic piece the brass goes into. Insert the brass nut from the back. Use the bolt and washer to draw the brass into the plastic. Undo the bolt, install the bolts that hold the plastic frame piece on. Install the plastic body panel. When tightening the repaired bolt, be gentle!
    Joe Meyer
    Jul 2015
    Quote Originally Posted by cptjam View Post
    Thanks, I'll give it a shot after work.
    2015 F3S
    lidloxs
    X Grip
    Ram mount
