Results 1 to 18 of 18
    Active Member SteveandBelinda's Avatar
    Jun 2016
    Canton, MI
    Default Garmin Zumo 590 & 660 - Can Am Dealer Database Update
    I just uploaded a supposedly newer database file of Can Am Dealers for your gps. Here is the url to the instructions and file. I am not sure to the validity of some of these dealers listed in this database, becuase there is one listed just
    up the road from me about 5 miles, and they are NOT a Can Am dealer but a BMW dealer.
    But I am sure that there are a lot that are Can Am dealers too.
    https://can-am.brp.com/spyder/owners...se-update.html
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    I clicked on "download" & got a tightly spaced page of abbreviated info. no file name as far as I could see.
    Opening the Zumo 660 was ok but what the heck do I do with the page of info?
    The instructions say "locate the downloaded dealer database file (example, D2245000B.gpi) Highlight the file, select Edit, copy...… How do you insert that page of abbreviated text which has no file #?
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Jul 2011
    Mitchell, Ontario, Canada
    The "E" dealer database I think is more than a year old. So there will be some changes since then.
    Oldgoat, follow the instruction for the 660. Which when simplified. Download the file to a computer. Do not open it. Plug your gps into the same computer using a usb cable. Using a file manager open your gps like any other hard drive. Find the file named "D2245000B.gpi" The B could be a C or D. Rename it. Unusually found in the GPI folder. Copy the file you downloaded D2245000E.gpi from your computer to your gps. Done.
    2018 F3 LIMITED
    Jul 2014
    Mint Hill, NC
    FWIW, on my 590 that I have kept continually updated since new I found one D2245000E.gpi file dated Jan ?, 2017 in the POI folder. I renamed it D2245000EOLD.gpi then copied the new downloaded file to the POI folder and deleted the ...EOLD.gpi file. Very easy.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Thank you billy & jay. When i open the link on my tablet, all is ok & i get the required file. When i open the link on my pc i get the page crammed with text & no file #.
    I will transfer the file from my tablet to my pc then put it onto my zumo 660.
    Merci
    All done.
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    Thanks for the info!
    It was a snap to download & install and way more locations than the file I had!
    2014 RT-Ltd , Cognac
    Jul 2011
    It looks like your old file was "E" as the last digit. So the file you downloaded was the same file. If and when BRP updates it. The file should change to a "F"
    2018 F3 LIMITED
    Apr 2017
    North Central Florida
    It looks like your old file was "E" as the last digit. So the file you downloaded was the same file. If and when BRP updates it. The file should change to a "D"
    Are they really going backwards UP the alphabet like that ??
    Jul 2011
    Quote Originally Posted by Easy Rider View Post
    Opps my mistake. i will have to relearn the alphabet.
    2018 F3 LIMITED
    Active Member TheCajun1957's Avatar
    Jun 2016
    Kilgore Tx.
    Quote Originally Posted by oldgoat View Post
    I too pressed the download button and got the compressed info page. I can not figure out how to download the file itself, it just keeps showing me what is inside the file. Do I highlight the entire page and try to save it had the file. Still confused?
    Once I have the file it should be not problem placing it on the 660. Just need the file.
    2018 White F3 Limited
    Quote Originally Posted by TheCajun1957 View Post
    If I click on download while on my pc, I get the page full of text.
    If I click on download while on my tablet it downloads the file correctly
    Don't know why.
    I then emailed the file to myself & opened the email on my pc. I now had the file on my pc
    Plugged in the zumo & transferred the file.
    That may have been a very roundabout way for computer experts, but solved my problem.
    Oct 2013
    Farmington, Delaware
    Try a right mouse click on the download link and choose save as.
    The reason it is opening the file when you download is because of the file associations on your PC.
    SpyDel
    2017 F3 Limited
    Quote Originally Posted by Spydel View Post
    Thank you
    Jul 2014
    Mint Hill, NC
    For another FWIW, today I sent the message below to BRPCare.
    "On 6/28/18 I downloaded the latest database for installation on my Zumo 590 per the instructions at this web site:
    https://can-am.brp.com/spyder/owners...se-update.html. The file I downloaded was D2245000E.gpi. When I connected my Zumo to my computer and selected the POI folder on the Zumo I found there was a file, D2245000E.gpi with a January 2017 date shown in the properties of the file. That date is reasonably the last time I downloaded and installed a dealer database update. I renamed this January 2017 dated file D2245000EOLD.gpi and copied the newly downloaded file to the POI folder. I then deleted the D2245000EOLD.gpi file. Since both files originally had the same file name but different property dates, please confirm for me that the file I downloaded on 6/28/18 is in fact the latest version of the dealer database despite the fact that the two files created a year and a half apart have exactly the same file name. Kindly do not tell me to contact my local BRP dealer because that dealer does not maintain your corporate dealer database; you do. Thank you very much."
    Cognac 2014 RT-S
    Jun 2016
    Kilgore Tx.
    GOT IT! Downloaded it on my pad and then mailed it to myself. Then followed the rest of the instructions.
    Thank Yall!
    Jul 2014
    Mint Hill, NC
    Here's a very prompt response, 24 hours, to my question to BRP about the latest dealer database.
    "Thank you for taking the time to contact BRP with your inquiry about the latest Dealer Location Database version.
    In response to your request, we are writing to advise you that the file you found on the website is in fact the latest version available, regardless of the file name.
    Should you have any other questions or comments, do not hesitate to reach us by replying to this email or call us at 1-888-272-9222.
    Once again, thank you for contacting BRP."
    Cognac 2014 RT-S
    Jul 2011
    Just downloaded the file again. Using on of the links in this thread. Creation and Modified dates are today as assigned by windows. Not the day the file was created by BRP.
    I had to use the link on a previous post because the link is no longer on BRP's website. Maybe no longer going to offer it.
    2018 F3 LIMITED
    Jul 2014
    Mint Hill, NC
    Yeah, Billy, I noticed when I downloaded it on the 28th that Windows assigned a 7/28 date in the properties and I downloaded it again yesterday and got a 7/2 date. The old 2017 date on my Zumo POI folder was probably the last time I updated the database because I always dump all the old versions per the instructions. I still would think that BRP would want to have a different file name for every update version and not reuse an old file name. Who knows???
    Cognac 2014 RT-S
