Results 1 to 11 of 11
    Active Member Many brands's Avatar
    Aug 2016
    Atwater, California
    Default Torque value (In ft/lbs) for the Oiul drain plugs
    I have been through the threads - but cannot really find the Torque values - for re-instally my new oil plugs. Thanks in advance
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Off the top of my head, I believe it’s 15 ft lb +/- 2 for a 998. Don’t know about a 1330.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Dec 2012
    Murphy, NC
    Default TORQUE VALUES FOR OIL PLUGS
    I have done oil changes on an earlier 998 engine and now do oil changes on my 1330. I wouldn't worry about specific torque specifications on oil plugs. I just finger tighten as hard as I can and then use the wrench to give the plugs another 1/4 turn. I've never had a problem using this system.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Aug 2016
    Atwater, California
    Default Re-
    The reason I am asking - is I have read so many horror stories - of striping threads, busting the plugs, etc. Just though I would "get it right".
    If you have a 1330 engine, torque specs:
    Oil sump drain plug = 21 lbft +/- 1 lbft.
    Clutch cover (aka transmission) drain plug = 15 lbft +/- 1 lbft.
    Oil filter cover = 18 lbft +/- 2 lbft.
    Default Lets see....
    JKMSPYDER
    make sure you have a new crush washer as they will absorb any vibration that could loosen the plug. Have always done it this way on all vehicles in all the shops I worked or owned... torque wrenches are normally longer than other tools and therefore make it easy to over do things....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2014
    Benson, NY
    Torque Wrench Use and Care Tips
    • Tighten fasteners in two steps—first to half torque and then to final torque.
    • Clean dirty or rusted threads before tightening, but don't lubricate them unless instructed to by the equipment manufacturer.
    • Always dial the wrench back to zero (never below zero) when you're done with it.
    I don't torque the oil plugs because it's near impossible to keep oil from getting on the threads and overtightening them. I use the "snug it up and give it a touch more" method.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Active Member dickgi's Avatar
    Aug 2017
    Saskatoon
    Do you know if the oil filter cover torque is the same for the 998? I am going to a DYI oil change and want to know how tight they have to be when I put them back on. The service manual does not say.
    Sorry, I do not know what the 998 filter cover torque is and it is an entirely different design than the 1330 engine.
    Default Torque Wrench
    Quote Originally Posted by Many brands View Post
    I grew up without one, and I must have been very lucky.....that being said on low Torque bolts ,like the oil plugs ….Just make them tight - if they leak make it a tad tighter ….. the Torque isn't critical like the engine, trans, and suspension bolts ...jmho …. Mike
    Aug 2017
    Saskatoon
    How tight did you main the oil filter covers for the 998?
    Quote Originally Posted by JKMSPYDER View Post
