My Adventure(the good, bad and indifferent) from west Texas to North East Tennessee.
We left west Texas on June the 15th for Tennessee. We and stay the first night at my father-in laws. We made our treck across Arkansas to Winchester, TN. Bike did well for the most part. Stayed in Winchester from the 17th to the 23rd. I am getting an P0550 fault code (DPS). Dymanic Power Steering. The steering gets hard to turn with no assistant. If I stop and shut the engine off, it will reset the code and all is good. I talked to a Spyder service dept, and it seems to be a problem. There was 3 other ones that same week. If I sent the bike to him, he would have to diagnose the problem, and sent the problem up the BRP flag pole. He said it would take 3 to 4 days to gwt the $1000 part to replace, if it doesn't get held up in customs. And it would take a whole day just to strip apart to front end of the bike to replace it. So unfortunately I don't have time to leave it, cause this is my only transportation. I will have to deal with it when i get back home. Still have trouble with the Bluetooth on the bike. Sometimes it wont connect to my helment or my wife's and vise versa. My dealer back home still as of yet, have the firmware update for the bike. Other than that, the bike runs great.
More postings to come.
Problem
You might want to check your battery. I'm told when it gets weak it starts shutting down less important uses, such as power steering.
Joe
I assume it's ok. It's a new bike. 2018 RT Limited
That's messed up
A brand new, 2018 bike and it already needs a $1,000.00 repair.
Greg Kamer
USAF, 20 years, retired
2018 Can Am Spyder RT-Limited
Yep. And it's frustrating.
Little checking.....
The DPS is the biggest electrical draw on the spyder. (all of them) and a weak battery or faulty connection can cause this kind of problem. I seem to have seen some spyders of late that have had loose ground strap connection but regardless start there...
2012 RS sm5
mine too
My 2013 RT was just that. Grabbed the pos cable and couldn't move it. Grabbed the neg cable and was able to move with a little force, Tightened up bolt and problem solved. Never showed up on voltmeter or starting.
I will check that to see if there is any loss cable. Do y'all have an issue with vibration when you reach highway speeds? My has a vibration in the front from 70mph to 75mph.
safe travels
Let us know when you make it home, safe travels friend. Rick & Kathy
Rick & Kathy
currently Henderson County NC from Ellis County TX
2021 RTL
Thank you. I might make a YouTube video about my trip amd all the stuff that when on.
Always check the connections to the battery! This will cause random electrical issues! I'm always surprised how easy it can loosen over time.
2015 RT Limited: Fox Shocks - RonJon swaybar and links - BRP Comfort Seat - BRP Triaxis handlebars - Yokohama tires (26psi fronts 28psi back) - Centramatic wheel balancers - BRP belt tensioner - BRP Short windshield - CATdelete/Spyder1 attitude exhaust - Lamonster footpegs - sintered brake pads - LED TRYCLED lights - BumpSkid
Gene that used to be true but I was told that the “brushless power steering” that they went to in 17 is no longer a power sucker.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Well, we are on pur way home now. I did tighten up the ground cable on the battery. It did quite for a day, but cam back while i was driving on the interstate. Will get it checked out when i get back to west Texas.
New spyder use the Warranty!
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
