Results 1 to 10 of 10
Thread: Front Shaking
    Invalid Emails
    Jan 2013
    Massachusetts
    Unhappy Front Shaking
    I have a 2012 RT that has a shake at about 35 MPH any thoughts?
    Roger G
    2012 RT , Blue
    Sep 2014
    USA
    balance,bearings,tires,steering links..Somethings to check
    Invalid Emails
    Jan 2013
    Massachusetts
    Quote Originally Posted by rguitar1 View Post
    Roger G
    Will check, thanks
    2012 RT , Blue
    Invalid Emails
    Jan 2013
    Massachusetts
    Roger more info from you on this will / can narrow down the possibilities greatly ....... Help us help you ..... mike
    Bike has 26000 Miles and always had a slight shake in the front dealer told me that this is normal.
    The severe shaking started last week,almost too much to tolerate.
    2012 RT , Blue
    Dec 2015
    Oakley Utah
    When did you last replace the front tires (mileage and date)?
    2014 RTL Platinum
    Jun 2013
    East Aurora N.Y. U.S.A.
    Default Front tires
    My 2011 RT was doing the shake at 45 mph. After balancing little improvement, swapped tires and wheels from one side to the other and shake was gone. Stock Kendas looked like new and were wearing evenly across. New front tires end of problem (not Kendas).
    Sep 2013
    Houston
    Front end shaking is NOT normal and is a sign something is going wrong and needs tending to.
    I really hate dealers that respond this way when they simply don't know what is wrong or are too lazy to figure it out.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Aug 2007
    Greeneville, TN
    Customers get this all the time from dealerships for just about every aliment a Spyder may have. And it's about 99% bull pucky! The front end should never shake on a Spyder. If it does, something is wrong and needs to be addressed.
    I don't know if the dealerships say this because they don't know how to fix it, of if they just don't want to deal with it.
    As many have said, it's probably wheel balance (fixable). Or it may be a cord separation issue (not fixable). Especially if you have Kenda tires. But it can also be worn front end components like A-Arm bushings or tie rod ends. Though these will usually give you more shaking when braking.
    Let us know what you find.
    Member RVG RT1's Avatar
    Jun 2018
    Orange, Ca.
    Default shaking front end
    The last couple of runs I made on my RT my front end would shake between 43-46mph only, then run smooth at any other speed. Saturday I checked my tires for air pressure and found my front tires both @ 18 psi so I raised them to 20 psi cold and went for a run with my neighbor on his HD and I found that I no longer had any shaking at any speed. Since I'm new to the Can Am from 2 wheels, I guess on these bike just 2 psi can make a big difference or at least on OEM tires and with just over 12K mi. and no sign of cupping or alignment problems.
    IF IT'S NOT BROKEN LEAVE IT ALONE
    2014 White Spyder RT LTD
    Active Member thunor's Avatar
    May 2015
    Lyons, NY
    Default Front Shaking/Cupping
    Beginning of the season I had oil change done and had them verify that the shaking in the front at 45 mph was due to cupping
    on the tires. They agreed. Considering they are about to hit 35,000 miles I think I made out better than most others. Even the
    rear OEM I swapped out with a car tire at about 18,000...it is still doing great. I will match my fronts with the replacement rear
    but I am surprised to see the very low mileage that everyone else appears to be getting. I know they are cheapo tires but still the
    front end should have a lot less wear as it generates far less traction needs.
    1984-87 Kawasaki GPZ750(1983)
    2011 Kawasaki Vulcan 800(2005)
    2012 Victory V92SC(2009)
    2013 Harley Davidson Road King(1999)
    2015 Can Am Spyder RT-S SM6(2014)
    2014 RTS , White
