Results 1 to 13 of 13
    Active Member _..stiffler..'s Avatar
    Feb 2015
    NB Canada
    Default 195/50/15 on the front?
    Anyone try 195/50/15 on the front of the F3S?
    It’s only about half an inch higher and just over 1 inch wider.
    There is a lot more tire choices at that.
    And will it mess with any electronics??
    I have searched for that size and found nothing.
    Thanks
    stiff
    2011 RT Limited , White
    Jun 2014
    ny
    Hell no, rubbing issues
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default 175/50r15
    i'm running the HANKOOK VENTUS V4 ES 175/50R15 up front on my 2015 F3-S, and i have NO issues with rubbing or anything else...
    the 175's allow for a gap of between 1/4" to 3/8" between the sidewall of the tire, and fenders & mounts...
    Dan P
    SPYD3R
    May 2008
    catskill,ny
    How about this combo ?? Kumho Exsta AST 225/50/15 for rear and Vredestein Quatrac 5 175/55/15. I know the Kumho is tie of choice. But what about the Vredestein for the front?? Will the size fit/work??? What about tread pattern??
    May 2008
    catskill,ny
    Vulcan tire has the Vredestein front tires in all sizes. Kumho Ecsta AST has to be found elsewhere
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Default 195 45R15
    Friend has this size on front with no rubbing issues. I will be looking at this size next time I change front tires.
    Ride safe!
    2022 Sea-T0-Sky
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    There is so much more to this question than will it upset the nanny. Sure, you may be able to CRAM that tire on the wheel and get it to air up.... BUT, just cuz it fits doesn't mean it will perform well. You will be contorting the sidewalls inward which then forces an outward bow of the tread area. This results in LESS contact patch consistently meeting the road surface. The sidewalls of a radial tire are designed to work in a rather narrow angle of operation (relative to vertical) due to where the bead plies end and the sidewall transition begins. This area is rather weak compared to the rest of the tire. Sidewalls are 2 ply vs 4 for the tread of the average tire and not as inherently strong.
    It is the inverse of the folks that use tires that are WAAAAAAY too narrow for a wheel and stretch them out to fit for a "cool stretched look" (in their opinion), the stresses placed on the sidewalls are enormous and depending on how extreme it is taken, dangerous and deadly.... facepalm.gif
    Chuck
    Jul 2013
    Bellmore,NY
    What type Fenders does the friend have .....it makes a big difference in fitment ...... Mike
    The new style fender.
    Ride safe!
    2022 Sea-T0-Sky
    Jul 2013
    Bellmore,NY
    The same fenders I have on my 2013 RT-S.
    Ride safe!
    2022 Sea-T0-Sky
    Jul 2013
    Bellmore,NY
    This is the tire he has on the front.
    TOYO
    PROXES T1R
    Ride safe!
    2022 Sea-T0-Sky
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    The Toyo T1-R in 195/45/15 is an interesting thought as it's one of the few sizes of T1-R available here in the UK.
    I also remember the being described as very small for the size from when I had my EVO VII, so doesn't surprise me that they fit under the arches.
    This is the size comparison to stock:
    (stock on left)
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Jun 2016
    NorCal - Northbay
    [QUOTE=monkeyboymorton;1372218]The Toyo T1-R in 195/45/15 is an interesting thought as it's one of the few sizes of T1-R available here in the UK./QUOTE]
    You guys have ALL of the T1R's in 225/50-15!
    Chuck
    Sep 2015
    UK
    Quote Originally Posted by hypurone View Post
    LOL!! Yes I've seen we can get them for the rear. Unfortunately the Yoko S-Drive is not available here anymore as that would be my first choice for the rear. T1-R is my fall back position and my original Kenda is nearly done.
