Results 1 to 25 of 28
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Default All 2013-up with Brembo brakes (Parking brake arm bolt check) WARNING
    Two days ago while out for a ride, the bracket that bolts on to the rear brake caliper and that the brake cable hooks on to fell off my bike. I did not notice this till I got home and tried to set the parking brake. Somehow the bolt must have vibrated loose. The problem, BRP does not offer the bracket seperately. But you can buy the spring and bolt which holds the arm onto the caliper. Make sure the bolt is good and tight when ever you have brakes serviced.
    BRP should make this available. Why force us to buy a whole new exspensive caliper assembly, when all we need is the Arm, Spring, & Bolt - probably less than $60.00. We've already spent enough for the bike.
    Attached Below is the picture of the Bracket in question. It's bolted to the caliper with spring attached at the bottom cable hooked at the top. Make sure this bolt is tight each time you have brakes done.
    Ride safe!
    2022 Sea-T0-Sky
    Jul 2015
    Dorr, michigan
    Quote Originally Posted by taxmyzer View Post
    Attached Below is the picture of the Bracket in question. It's bolted to the caliper with spring attached at the bottom cable hooked at the top. Make sure this bolt is tight each time you have brakes done.....
    Try this part number 219800241. It says that it is CAN-AM - CABLE SUPPORT/LEVER FOR REAR
    http://www.2wheelpros.com/oem-parts/...0241-part.html Just over $30
    2020 RT Limited , Petrol Blue
    May 2014
    Benson, NY
    Thanks... I'll be checking mine before I hit the road again.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Jul 2013
    Bellmore,NY
    Default Not the correct bracket
    Quote Originally Posted by Fatcycledaddy View Post
    According to my dealer the bracket in that kit is not the correct one I need. Waiting to hear back from BRP as to which kit has the bracket I need.
    Ride safe!
    2022 Sea-T0-Sky
    Jul 2013
    Bellmore,NY
    Default Pictture added
    Updated post.
    Ride safe!
    2022 Sea-T0-Sky
    Nov 2016
    Upstate NY
    Default I made you one.
    Here ya go. Fits and functions perfect.
    Jul 2013
    Bellmore,NY
    Quote Originally Posted by Joel The Biker View Post
    Thank you Joel.
    Over the years we've made great friends through this forum. Today is a perfect example of the Spyder community coming together to solve problems.
    Ride safe!
    2022 Sea-T0-Sky
    Nov 2016
    Upstate NY
    Default Thanks
    Thanks Jose. I am always willing to help out my friends. It was kinda fun to make. I guess I was a little bored this morning.
    May 2014
    Benson, NY
    Attaboy Joel! I took mine off today, cleaned up the threads and put a dab of loc tite on it.
    Sena 20s
    Sep 2012
    Stetson, Maine
    Joel, that was great thing you did there. My hat is off to you. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Northern Kalifornia
    Joel, you should be working for BRP. At the very least, they should hire you to improve their customer service. Your an "A+" guy.
    Jul 2013
    Bellmore,NY
    Default Parking brake Arm
    Joel, thanks once again, got the bracket you made today It's installed and working perfectly.
    Ride safe!
    2022 Sea-T0-Sky
    Jul 2010
    Las Vegas, NV
    Default Very cool!
    Sweet! That's why this forum rocks! Nice job, Joel!
    Joe Meyer
    Arizona
    Default Wow - nice job
    You are great Joel and very talented - what a nice thing to do.
    2016 RT Limited - Red: Purchased from Pikes Peak Motorsports
    Dealer installed: TriAxis Bars;
    Self Installed: BahaRon SwayBar, Bumpskid, Corbin Armrests, Dave's BT Cable, ShowChrome Luggage Rack,Foam Grips
    Wishlist: Fox Shocks, Long Distance Seat, HID Headlights
    What did you use to make it, a plasma cutter or water jet cutter, or something else of the sort? I was wondering how you duplicated the shape. Make a digitized copy and load the CNC or is there some way to trace the original shape? I'm just curious. I guess it's my engineer nature.
    Nov 2016
    Upstate NY
    I made it by hand with hand tools. Sawsall, grinder, drill, files, and a sander. Took about an hour.
    Mar 2018
    Ontario ,way up north
    You the man .
    2018 RTL , dark blue
    Jul 2013
    Bellmore,NY
    Default Update
    Called my dealer today to check on status of technical request sent to BRP. As my initial post stated it was regarding the parking brake lever that fell off the rear brake caliper of my 2013 RT-S. I was told by my dealer that BRP sent them a replacement part. Kudos to BRP for stepping up to the plate. Heading upstate tomorrow to have new bracket installed.
    Ride safe!
    2022 Sea-T0-Sky
    Nov 2016
    Upstate NY
    Default Klinger's?
    Are you going to Klinger's in Walton?
    Jul 2013
    Bellmore,NY
    Default No
    I will be in Rosendale, NY.
    Ride safe!
    2022 Sea-T0-Sky
    Active Member Stumpy6Guns's Avatar
    May 2016
    Valley Center, CA
    Default Craftsman in action!
    What a joy to see that hand craftsmanship is alive and well! Great job, Joel!
    Myron Wooley
    USMC 1975 - 1979
    2nd Spyder: Pearl White 2016 Spyder RT Limited, purchased December 18, 2016 with 1 mile
    First Spyder: Pearl White 2012 Spyder RT Limited, gone to a good home
    Jul 2013
    Bellmore,NY
    Default Nevet would have knowm
    You have to see it to really appreciate the workmanship. I will keeping this as a spare just in case.
    Ride safe!
    2022 Sea-T0-Sky
    Nov 2016
    Upstate NY
    I would have made it a little prettier, but had to get it to the post office before it closed. Function over style I guess. I think the paint was still drying when I mailed it!
    Quote Originally Posted by Stumpy6Guns View Post
    Jun 2021
    New York
    Hi,
    I'm hoping you can help me with the part number for the spring and bolt. I just noticed that my bolt isn't there and i cant find the part number. I still have the spring but I'll be happy to buy both if that's how they come.
