Results 1 to 16 of 16
    Active Member Garydj's Avatar
    May 2018
    Olathe KS
    Angry Installing Ram ball mount on center bolt
    I bought a ram ball mount and bracket from Value Accessories. I had to buy a special set of allen wrenches as every set that I had missed out the 7 mm wrench. Why do they do that?!
    Now that I have the correct wrench for the bolt, it will not budge! Does it take an impact wrench to break it free?
    Gary
    US Army Vietnam era vet
    2023 Can Am F3
    2020 Can Am Ryker 900 ACE (traded)
    2013 Can Am Spyder RT SE5 (traded)
    2012 Suzuki Burgman 400 (sold)
    2012 Honda NC700X (sold)
    2012 Honda CBR250 (sold)
    States visited on 2 or 3
    2020 900 Ace , Black on black
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Garydj View Post
    I bought a ram ball mount and bracket from Value Accessories. I had to buy a special set of allen wrenches as every set that I had missed out the 7 mm wrench. Why do they do that?! Now that I have the correct wrench for the bolt, it will not budge! Does it take an impact wrench to break it free?
    Don't know what you're talking about. How about a link to the product?
    2014 RTL Platinum
    May 2018
    Olathe KS
    http://store.valueaccessories.net/Sp...MMountKit.aspx
    Gary
    2023 Can Am F3
    Very Active Member 2Paw's Avatar
    Feb 2013
    USA, Texas, Mckinney
    He's trying to break loose one of the bolts that hold the handlebars on, so he can replace it with a bolt that has a ram ball on the end of it.
    edit: Well I just saw his new post and it is a different product, but he is still trying to break free the same bolt.
    Ed
    They told me not to give up on my dreams, so I went back to sleep.
    Champagne 2017 RTS SE6
    Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
    Jul 2015
    Easley, SC
    You really need a hex bit socket to do this job. The bolts are on really tight with locktite.
    2015 RS SM5, Navy F4 Fighter wrap
    Passenger Backrest, RT Handlebars,
    BRP Comfort Seat, Airhawk R cushion,
    Garmin 660LM GPS, LidLox, Can-AM Top case
    Dec 2015
    Oakley Utah
    They probably used some form of lock-tite thread locker so it wouldn't come loose. I don't know what kind of hex wrench you got, but probably the handle isn't long enough to give you the leverage you need. If so, look for a piece of pipe or something to extend the wrench handle.
    2014 RTL Platinum
    Jul 2015
    Easley, SC
    You have to remove the original bolt and replace it with a longer bolt and spacer to allow the ram mount to fit.
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Default Takes Some Effort
    Need a 7 mm hex bit for a socket wrench. Takes a lot of torque to break the loctite. I was able to get mine with a standard socket handle, but if you use a cheater, make sure the bit stays fully engaged in the bolt to prevent slipping and stripping the head. Be patient and you will be successful. Good luck!
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Boilermaker View Post
    And, don't forget that you will have to use the correct torque on the bolt after you re-install it ....
    2014 RTL Platinum
    Feb 2017
    ST LOUIS MO
    you guys or the cools people in the world someone have a problem you just jump right in an help man i love this spyder family
    Jun 2010
    Las Vegas
    A T-handle allen works well. You can get better leverage with the T than with a basic allen wrench.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2017
    Massachusetts
    Default I had the same problem
    Then I bought this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Get a hammer and let your frustrations out! It worked like a champ.
    2017 Can-Am Spyder RT
    Jun 2011
    Kerrville, Texas, USA
    Default +1 on the hex bit socket
    Quote Originally Posted by GK72Cane View Post
    Truer words...
    Had the same issue as you, and a normal allen wrench just won't cut it. Here was my adventure:
    http://www.spyderlovers.com/forums/s...10#post1357810
    Regards,
    Bret
    2017 RT-S Orbital Blue
    BajaRon Anti-Sway Bar
    SpyderPops LED Bumpskid, Spyclops II LED, Full View Turn Signals & Belt Guard
    Sena 20S Bluetooth Headsets
    Brake Free Helmet Light
    FOBO Bike for Trike
    Rugged Geek RG1000 Safety Plus Jump Starter/Air Compressor
    Lamonster RAM mount/Techmount TechGripper
    Drink2Go Cup Holders
    UltraGard Half Cover
    2017 RT-S , Orbital Blue
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    You can also get the bolt hot using a soldering iron. It doesn't have to be too hot, just hot enough that you can't directly touch it. That's all it takes to melt the loctite.
    2020 RTL SE6
    May 2018
    Olathe KS
    Thanks for all the responses! I bought a T handle wrench in the 7 mm size, but don't have the strength to break it free. I have connected with the KC Spyder Riders club and will see if someone with better tools is able to assist me. Until then my phone will ride in the top case where I can hear it at least with the Bluetooth.
    Gary
    2023 Can Am F3
    Dec 2015
    Oakley Utah
    A T-handle wrench is not going to provide enough torque to break it free, unless you happen to be a former paratrooper
    The best solution has been suggested before; get a 3/8" or 1/2" socket wrench, along with a set of metric sockets AND hex and torx sockets in the common sizes used on a Spyder. You are going to need these anyway if you tackle any projects on the Spyder, including oil changes.
    These won't cost much at Harbor Freight, and will be plenty good enough for D-I-Y projects. While there, also get a decent torque wrench if you don't already have one.
    2014 RTL Platinum
