Replacing wiindshield on 2016 RTS
What type screwdriver? What size screwdriver? Take it off at brackets? Can't see well enough to determine if Allen or torx, don't want to use wrong one and mess up. Thought I would ask first.
You know those little plastic trim pieces on the windshield?
Remove the screw from the back side of it...
It uses a Torx bit: (forgot the size... )
Once that's out: put a playing card underneath the bottom edge of it (to prevent scratching!), and push it downward.
It'll pop out, and give you full access to the four Torx screws that need removing.
(I think that this is one size up, from the size that I forgot earlier!)
SpyderLovers Sponsor
Installing your RT windshields
Hope this helps.
Don Frank
F4 Customs
F4 Customs, Inc.
"The Motorcycle Windshield Folks"
941-347-7496
sales@f4customs.com
<a href='http://www.spyderlovers.com/adserver/www/delivery/ck.php?zoneid=22' target='_blank'><img src='http://www.spyderlovers.com/adserver/www/delivery/avw.php?zoneid=22&cb=567846784' border='0' alt='' /></a>
Thanks for the video!
Do you happen to know the two size Torx bits that are needed?
Torx 25 for the trim covers, then Torx 27 or 30 for the rest of the machine screws
The first 2 screws to remove the trim covers come off with a Torx 25. Just keep your hand on them while removing as they can drop down into the never, never land!! I just switched out my windshield for a trimmed down version.
07 Shadows, Aero, Spirit gone but not forgotten
03 Harley Sportster, 07 RK moved on
11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
Trim is Torx 25 & windshield is Torx 30
