Originally Posted by SPYD3R
keep in mind that the computer will compensate for octane variations and elevations...
Not completely.
There is no "octane detector" as such.
Do I need to explain the difference between "spark knock" and "compression knock" yet again ??
cpu
Originally Posted by Easy Rider
Not completely.
the CPU will retard/advance the spark for variations to the point where you'll never notice any gain/loss in performance....
Still wrong. There are no "variations". If the maximum spark advance causes ping, the advance will be dialed back.
Exactly how much and how often it is sampled varies from one type of engine to another.......but ALL it has to go on is the presence or absence of a ping immediately after the spark is delivered.
ok
ok, you win...
Not completely.
…" There is no "octane detector" as such."
Well this isn't quite right either, is it - particularly if we start to think a bit more laterally ? … There is indeed an 'octane sensor' but in a slight variation in the form of the O2 sensor which is found mounted about the area of my exhaust collector on my F3-T, thereby collectively sampling all three exhaust port gas groups in that one area. In fact that is a very important part of its job … Among other functions, the O2 sensor controls or contributes to many different engine functions, including fuel/air mixture, engine timing and engine combustion intervals via the ECU.
Originally Posted by fatenhappy
…… There is indeed an 'octane sensor' but in a slight variation in the form of the O2 sensor
Oxygen and octane are entirely different things. The oxygen sensor can NOT detect any changes from different octane ratings of the fuel in use.
My smoke detector is going off.
don't you think that it'd just be easier to say that "They have set the 1330 up to run best on 91 Octane.", and let it go at that?
Yes but that is only PART of the story.
As was indicated in another post, under some circumstances having a fuel that is too low in octane rating can actually damage the engine.
AND under those circumstances, the engine computer can NOT save it.
Thankfully most owners never encounter that kind of situation so they can get away with burning whatever is available commercially.
NOW......if you go up to a high altitude and fill up with the low octane stuff that they sell there......and immediately go back down to sea level and ride it REALLY hard.......all bets are off.
Mention of Ethyl...
I saw this in two different posts and maybe this is being picky but here goes.. Ethyl is Tetra Ethyl Lead that used to be in gas before the Unleaded revolution and is not related to Ethanol. Premium gas like Chevron White Pump or Sunoco 260 was what was referred to as premium in the old days.. Today RON rating is strange in that is supposed to be the rating at the pump. FWIW I use premium in my bikes and always have because down stream at overhaul the cleaner burning gas leaves fewer deposits.. I have started using Seafoam in everything I own if for nothing else than as a preservative. I used Lucas Injector cleaner in the past and my 2010 Ford had 320,000 miles on it when I sold it and still got 19mpg and no oil use between changes.. Just Sayin'
Well those are two good ways to just throw your money away.
So called "premium" gas does NOT automatically "burn cleaner".
And SeaFoam is just snake oil.....mostly.
It is a minimally respectable fuel stabilizer......but "everything you own" certainly does not need a stabilizer all the time.
All the rest that is claimed for it is mostly marketing hype.
But do whatever makes you happy, just don't try to convince me that I should do that too.
I made no mention on what others should do..this is my opinion..that what FWIW means.. and most everything I have can go a month between fill ups and the "new" unleaded formulations with the clean air chemicals lasts about 30 days before going sour..don't get so cranky..just suggestions..
Originally Posted by [COLOR=black
Your (Australian) 91,95, 98 Octane ratings is North America equivalent to 87,91,93 … [/COLOR]
Down here in Alabama, the selections are 87, 89, and 93.
Even more complicated - altitude effects
Here in Colorado, you can hardly find 93 octane. Most carry 85 / 87 / 91. My Spyder and my other bikes run fine on 87 at 6000ft, no need to pour my money down the tank. Once in a while I will put 91 in, but no seat of the pants data to tell if there's a difference in performance.
Also, with the Ethanol stuff, here's a website that lists by states where you can get pure no-ethyl gas. https://www.pure-gas.org/
JLohPhotos
