Results 1 to 11 of 11
Thread: Check DPS
    Active Member OlJim's Avatar
    May 2015
    NE Oklahoma
    Default Check DPS
    Is there anyone who has changed out their own DPS module. Got a P0551 and P0552 code that I can't get to clear no matter what I do. 2011 RTS SM5
    Default Oh no....!!!!
    Hopefully it is the ground connection or battery cause the DPS (dynamic power steering ) unit is around $1200.00 from cheapcycleparts.com but much more from dealer. There were issues with the DPS's back then you should check if yours was ever changed...
    ​2012 RS sm5
    Default DPS
    ...the DPS has a large power draw and if there is a glitch in the system circuit it could be causing the Code ..... check connections and strength of Battery............ Mike
    May 2015
    NE Oklahoma
    Default DPS
    New battery and I have tightened connections till I'm afraid I'll strip the threads. Checked power at the fuse and at the DPS....OK
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    Default USED DPS
    If needed I do have a used dps with 1165 miles on it. $500. But check all other connections and ground, including main ground on engine.
    2014 RT SE6
    Default DPS
    Quote Originally Posted by OlJim View Post
    .....BUT ...... Have you removed the KEY at LEAST one foot from the ignition for at least 10min. ????? ....Did the codes CLEAR ??? , and did they come back later ???? ../... My 08 GS lit up like a Christmas ( codes ) for two years but never failed me ...... The Nanny is EXTREMELY sensitive and often shows issue that are non-existent ...... I hope this is your case too ...............Mike
    Active Member Kennard's Avatar
    Mar 2012
    Franklin, North Carolina
    Default Replaced one last month
    My wife’s 2011 RT/S DPS died last month. One week and $1800.00 cured the failed unit but I like a lot of you wonder if the unit was defective when new. My dealer stated the unit was not one involved in a recall, but I was always suspected it was failing. I came home with the old unit so some day I’ll bench it and paint it gold and hang it on the wall.
    May 2015
    NE Oklahoma
    Default DPS
    Like I stated in my original post I have done everything I can think of including reading most of the 200+ post dealing with "check DPS". What happened was I decided to unhook the analog gages. In order to remove the bezel you have to turn the steering all the way to the right or left. In my case I turned it left. After unhooking the wires on the gages I replaced the bezel and started the engine. The digital gages worked and with the bars still turned full left the check dps (big orange screen) showed up. I shut it down, straightened the bars and started it again.....big orange screen. Took it for a ride around the block and sure enough the steering was real tight in the corners. Checked codes and had P0551 and P0552.
    Default DPS ISSUE
    I don't gamble /bet ........... that being said, considering what you had done ( mechanically ) what do you think the odds are that ..... that and the instant Failure of the DPS are connected .... I think the odds are " zero " ....... believe it or not , folks here have fixed code issues just by completely dis-connecting the Battery....... I agree the DPS unit may very well have failed, but $1200 or so would not be my first choice for fixing it ..... If you aren't looking for other possible answers ... then get a new DPS............ and I REALLY hope that fixes your issue ....because it might not, and then well ................ Mike
    May 2015
    NE Oklahoma
    Default Check DPS
    Replaced DPS unit. All codes gone, back to square one. The DPS was a kinda PITA because of it's location but all in all not too bad. Had to buy a special socket $16 for the SAS magnet but everything else was straight forward. Cost $1200 but saved $600 in labor. I wonder if they can check the old unit to verify if it is really bad or I just finally tightened the right ground wire.
    May 2015
    NE Oklahoma
    Default Check DPS
    Called the dealer this morning and was told I didn't need an appointment to have the steering sensors reset so loaded the bike on the trailer and off I went. Probably would have taken about 15 minutes but had a software update that needed installed so took about 1/2 hour. Only paid for the BUDS hookup, 42.00. On the road again. Thanks all for the inputs.
