Results 1 to 6 of 6
    May 2018
    NC
    Cool 2017 F3 Limited handgrip size?
    Greetings All,
    I would like to replace the original hand-grips with Kuryakyn ISO grips but, I'm not sure if I have 7/8 inch or 1" handlebars. I looked in the manual and musta missed the info cause I t'ain't seeing it!
    At $75 a shot I want to make sure I order the correct grips the first time. Thanks!
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    The bars are 1 1/8" on my F3 base model.
    They may taper to a smaller diameter at the grip ends. Never had the grips off to check.
    2017 F3, SM6-basic black, plain and simple
    Jun 2016
    Harrington, Australia
    The handlebars on a Spyder are different because the bars themselves end at the grips....I.e. the grips are a separate component. This has been discussed before, but I can’t remember the outcome. I do believe ISO grips for a Goldwing fit..... If you do a search for replacement grips and Gold Wing you should find some references.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2016
    Here’s Lamont showing an ISO install.....there might be something in there....
    http://www.spyderlovers.com/forums/s...t=Grip+install
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    May 2018
    NC
    Default Handgrip replacement
    Thanks for the input Gentlemen! I'll do some research here on the board as well.
    Aug 2018
    Winchester, NH
    Default KURYAKYN ISO GRIPS 7/8 OR 1 INCH
    Want to up grade to a larger diameter grips for obvious comfort reasons. On my 17' F3L should I purchase a 1 inch or 7/8 inch set because it will go over the stock heated grips.. I am of belief the 7/8 will be too small as I will not remove but just trim the end of the stock grips so I can slide over the larger Kuryakyn set.
