Page 1 of 2 12 LastLast
Results 1 to 25 of 39
    Active Member Harmony 44's Avatar
    Jul 2015
    Saratoga New York
    Default Dreaded seat again
    Is it the seat or is my butt is broken. The stock seat had me squirming at mile 50 with no relief after a short stop. My ultimate seat is good to around mile 80 and with a 10 minute stop good for another 80. Should I try another seat or is this normal? I have never been comfortable on longer rides no matter what I was riding so it's probably me.
    2015 Rt S Se
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    Russell Day Long. The best by most anybody's standards. I'm on number seven. You can spend a ton of money on seats but if you buy Russell you will only spend it once.
    Linden, CA
    Default I can cure your sore butt problem
    There is no need to buy an expensive new seat..............
    All you need is one of my Motorcycle Dave's Seat Gel Kits. $79.95 that should fix the problem
    Call me 209-887-3283
    Ride Safe
    Dave
    Quote Originally Posted by Harmony 44 View Post
    Active Member TEWKS's Avatar
    Aug 2015
    Tewksbury, Ma.
    I suggest these all the time because they made a big difference for me. https://ldcomfort.com/Mens-Riding-Shorts.html
    Pat
    Feb 2012
    Spring City,Utah
    Ride Safe
    Dave
    While it may be you, rather then spend a whole bunch of money on another seat that may not work,follow Dave's suggestion. I don't have your problem,Except for a 1969 Norton I have been able to make do with the seat on any bike I rode. Until the Spyder. It was a 2 hour seat at best. I bought Dave's gel pad and installed it myself,with his help by phone. You will find him to be very personable,VERY HELPFUL,and very available. That change took my seat from a 2 hour ride to an all day rider day after day. I think with your past experience this cheaper mod will help you decide whether or not it is you for a lot less money,and it may just solve your problem. If not,your not out much. Even buying a power staple gun I was into the seat for around $100.00.I am not an upholster and if you feel such a mod is beyond you a real upholster could do the job fairly cheaply. Good luck in your quest. Nothing is more miserable then trying enjoy a motorcycle you can't get comfortable on.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Northern Kalifornia
    80 miles is about right for monkey butt if you're not a conditioned long distance rider. At 80 miles it's a good idea to stop and take a break, shake it off and loosen up for 10 or so. Not a bad practice for safety reasons and to recharge your internal stay alert batteries; if you know what I mean. And yes, Russell's day long is an excellent choice.
    Forget about all of the Asses in here, who are telling you what to do!
    You only need to listen to ONE Ass: your own!
    Everybody has their own level of comfort, and how to achieve it: happy shopping; while you find yours!
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    I can vouch for MotorcycleDaves Gel pads.
    And also try some LD Comfort shorts, if you haven't already.
    https://www.webbikeworld.com/ld-comfort-shorts-review/
    Also ---- https://alaskaleather.com/collection...pskin-buttpads --- or any like product, quite a few makers out there.
    Dec 2015
    Oakley Utah
    Default It's all about ergonomics
    Anyone who tries to give you advice without knowing the details of you and your bike setup is not being very helpful. You need to provide more information if you want meaningful advice.
    2014 RTL Platinum
    Active Member JayD's Avatar
    Oct 2015
    Cumming, Ga
    Default Drivers Seat
    My two cents. I've got an Ultimate seat and an Air Hawk. Can ride out a tank of gas.
    2014 Spyder RTS
    Tri Axis Handlebars
    Big Bike Trailer Harness
    Rivco Front Bumper (Black)
    Rivco Highway Pegs
    Ultimate Seat
    Garmin GPS
    Trailer Hitch
    Aluma XL Trailer
    Stainless Grill Covers
    Cupholder
    Spring Stiffeners
    Rivco Floorboards
    Active Member Jheck's Avatar
    Jun 2015
    sherburne, ny
    2AB4B3FD-A5AA-466C-93A2-1A4E32CEC0AF.jpegNothing wrong with my seat.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by JayD View Post
    So can I, but mine is a Spyder comfort seat and I don't use anything else.
    2014 RTL Platinum
    You are not alone. One complaint against 's is the seat. On the five I have owned--the OEM seemed to turn into mush at about 50 miles.
    I have replaced the seats on all five--usually within 500 miles of purchase. Also have used sheepskin gel and airhawk.
    Currently, both seats are BRP Comfort. I find them much better than OEM.
    There are many threads and recommendations from each one touting the brand they use. Unfortunately, you have to work through that to find the one that "suits" you.
    Visiting a gathering of 's will give you an idea what's out there and what will work for you. Good luck with the hunt.
    Active Member Rookiespyder's Avatar
    Jun 2017
    Hanover Ont Canada
    I have the same darn problem I thought it was just me. So someone told me to get in touch with alaskaleather.com so I am going to give them a try.
    2015 RT Limited
    May 2013
    Sacrament0, CA
    Our combo is Motorcycle Daves Gel Pad inserts in the stock seat. Alaska Leather Sheepskin pads over the seat.
    We've done multiple, back to back, 600 mile plus days in comfort.
    That's just us and our butts though. YBMV
    Nov 2013
    Central Texas
    Here's my 1 cent solution that has worked for me for several years on a stock seat. An Airhawk R inflatable cushion. Doesn't necessarily work for everyone, but it has for me, and it takes all of one minute to install. I had to experiment with how much or little air until I found my "sweet spot", but I'm happy with it.
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    I have an Ultimate seat but I still rotate in a gel seat I picked up at Costco. I change up my seating pressure points by alternating the two when I stop for gas, which is about every hour and a half on a long trip.
    Aug 2015
    Tewksbury, Ma.
    My theory on the stock Spyder seat issue is that BRP builds the seats using the same foam (density) as they use in their Ski-Doo line, which seems to work fine at winter weather temps. In other words, the foam they use is too soft. YAMMV.
    Pat
    Sep 2015
    Parkesburg,Pa
    I agree,works all the time for me
    Jun 2016
    Harrington, Australia
    The trouble is, you need to listen to all these Asses in here to know what options are available to you, Bob .
    Dave’s gel insert may be brilliant, but I have never had any luck with gel inserts. They just don’t work for me, but it’s obvious that Dave’s insert does work for many.
    Having tried virtually every seat and option out there, my first option now when buying a new bike is to head straight to Russell Day Long where they guarantee their tailored seat will give you all day comfort. They have not failed me on my last 5 bikes .
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    We use Air Hawks over the stock seats. Seems to work. By the time our butts start acting up, it's time to stop a bit. Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Dec 2015
    Oakley Utah
    Pete
    Where do you get those in Australia ?
    2014 RTL Platinum
    Jun 2016
    Glendale, Arizona
    Having recently transitioned from a Harley Ultra to the RTS I found the CanAm seat to be the most uncomfortable I have ever experienced. Partly due to the foot and leg ergonomics with my height. I finally ran across another rider who had a Corbin custom seat on his bike and he let me sit on it. I immediately ordered one for myself and I love it. It moves the rider back about one and a half to two inches, which makes a huge difference. We just returned from Tennessee where we spent a couple of 6 to 7 hour days riding the Smokey Mountains and the Tail of the Dragon 2 up. Stopped for a break about every two hours and it was great. The seat is terrific. Not so much the price. They're pretty pricey and I wouldn't bother to order the rider back rest if I had it to do over. It sits too high up and doesn't really provide any lumbar support. Before you spend the money, track down someone who has one and try it for yourself.
    Jun 2016
    Day-Long, Pete? You don’t get them here. You buy a second hand stock seat in the US, get it shipped to Russell, send Russell your on board photos and requirements, shell out $150 for shipping, et voila........a custom Day-Long seat magically appears on your door step to provide seating bliss.
    I have been caught out getting a Mustang shipped over, only to find it doesn’t work for me, and then either having to ship it back (much more expensive going from Aus to US), or trying to find a buyer out here. I now don’t bother with anything but DayLong, and just factor that cost into my purchase price
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
