DESS ERROR
It happened again. Stranded in Pennsylvania with the dreaded DESS ignition error symbol. I have a 2014 RT-S. The dealer acknowledges they don't really know what the cause is.
Googling search shows many Spyder owners have suffered the same. Has BRP done anything to fix this problem? Swagman.
Originally Posted by swagman
It happened again. Stranded in Pennsylvania with the dreaded DESS ignition error symbol. I have a 2014 RT-S. The dealer acknowledges they don't really know what the cause is. Googling search shows many Spyder owners have suffered the same. Has BRP done anything to fix this problem? Swagman.
It would be bike by bike. Most of us have not experienced that issue.
2014 RTL Platinum
There is a post by DEANNE at least 20 pages relating to the problem along with other posts here.
Do a SEARCH!
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
Do a SEARCH! AJ
http://www.spyderlovers.com/forums/s...ght=DESS+error
2014 RTL Platinum
Yes DESS module and or ignition switch.
Read the thread posted above.
Turn key on and off a few times and or leave for awhile come back and try to start bike. Get home and have repaired ASAP>
Oh yeah !!!
There is a lot to read about it here. Once it fails the best thing is to have the dealer replace the switch and module. Otherwise it will only get worse. I would make sure they change both...
2012 RS sm5
Wish I were closer, could have you up and running in less than 10 minutes and never see that error again. Truly wish more dealers would allow owners to just turn this defective system off.
I agree. Best thing to do is have the DESS disabled. Everytime I see these posts, I look to see where they live. I can disable it, but Maryland is too far.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Do a SEARCH!
AJ
AJ, Name correction : Deanna777.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Also have the dealership open up a case with BRP. Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
I was having the same thing happening more and more frequent. I purchased a DESS Module from Cheap Motorcycle Parts, Part #710004916. I replaced that and have never had the DESS Key again. If you don't have warranty it is not hard to change yourself.
2021 RT Limited
Asphalt Grey
Lamonster RT phone mount
Sena SMH-10
Lamonster Belt Tensioner w/ larger roller
Spyderpops Missing Belt Guard
Garmin's GPS
So you got that module replaced
Yes, I did it myself. It is not a hard thing to change it just takes some time.
2021 RT Limited
Asphalt Grey
Sena SMH-10
Garmin's GPS
getting my second one
dropped it off at the dealer and waiting to get it back just as well haven't had time to ride any way.it better be back for Deadwood .
Picky, picky, picky!
Deanna
2014 RT-S
With the 2015, the module replacement corrected the vast majority of that model year.
With 2014, you better get both replaced or you are headed for future problems.
AJ
2014 RT-S
Most/and people on this site know me as Deanna777 or Deanna.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
AJ
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
Tags for this Thread
