Results 1 to 9 of 9
    Active Member michrick's Avatar
    May 2015
    Liverpool, NY
    Default 2014 ST 998 torx / Allen question
    I know it's been asked I've search but can't find it. What are the size torx or Allen wrenches to remove my idol tank plug and my transmission drain plugs for doing an oil change. I think one is a 6 mm the other I'm un sure of??? Thanks much when I do the service I'm going to replace with gold plugs. Thanks much
    2016 RT Limited , White
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    The 998 RT's take a 5 and 6 mm Allen wrench. I can't say for sure about the ST's, but I would suspect that they would be the same, a 5 and 6 mm Allen.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by BoilerAnimal View Post
    I didn't notice the 998 reference. You're right.
    2014 RTL Platinum
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Default They are 6mm Allen
    Quote Originally Posted by michrick View Post
    I still have the plugs from our '11 RT & '13 ST. They are all (4) 6mm Allen.
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Apr 2013
    California
    Default 1330cc oil plugs
    Quote Originally Posted by nhoj View Post
    Transmission is a 6mm Allen The oil is a T45 Torx They both tend to strip if your not careful.
    Jul 2010
    Las Vegas, NV
    Quote Originally Posted by ncll View Post
    My experience as well. Oil (left) Torx, transmission is a 6mm Allen. Since I do about one a week, I’m pretty sure😃
    Joe Meyer
    May 2016
    Your header says "1330cc oil plugs". He was asking about a 998.
    2013 RT-S SE 5
    May 2015
    Liverpool, NY
    Yes it's a 998 engine I thought the two plugs were different one was Allen the other torx?. I also plan on putting gold plugs back in. Just trying to make sure I have the correct tools in my travel kit, I'm not at home and plan on doing it this weekend. Thanks much for all your help.
    Apr 2012
    The '11 RT and the '13 ST are 998's therefore NOT an T45 !!
    Just to be clear the OP was asking about a '14 ST which is a 998.
    The T45 Torx is used on the 1330 engines.
    I think the OP has the correct info now, both are 6mm Allen.
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
