Results 1 to 10 of 10
    Member Demndawg's Avatar
    May 2018
    DE
    Default Yet another heat post@
    I apologize now if this has been discussed to death but im new to the forum and there were actaully so many posts about this issue that it was overwhelming. I have a 2010 rss and the heat blowing onto my right shin is becoming unbearable. Keep in mind this was with the outside temp barely hitting 90 so im really concerned about summer temps. Most of what I found was regarding the rt models and a recall. Ive seen the three step kit from spyderpops but I’ve also read tha5 removing the lower panels will redirect the heat. Can you please help me narrow this down to the best option for my rss? My last ride before going into the hospital was unfortunately in heavy traffic and my leg actually started to blister. I know your probably sick of this topic but please help. I really want to enjoy my bike this summer and a long trip is out of the question until this is solved. Tia!
    Jun 2010
    Las Vegas
    Replace the exhaust gaskets and be sure you wear thick pants and boots.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Member hillrad's Avatar
    Jun 2015
    Hillsboro, Ohio
    You name it and I've installed every mod available and find the only actual help is the thick pants and boots. I will add... tall/high boots.
    Fog lights
    Tour wind screen & deflectors
    Auxiliary power
    KewlMetal - radiator web
    SpyderPops - Air Dam, Heat Shield & Air Management
    Rivco - floorboards
    Easy Risers
    ISCI - passenger armrests
    Canisterectomy Stant 10819 gas cap
    DYI rear splash guards
    Frunk light
    Handlebar foam grips,cup holder & mirrors
    Wool seat cover
    Rear rack bag
    Car tires Solar 175/65r14 - 215/60r15
    MSD 8.5mm Super Conductor Wires (DIY)
    LED strips brake/running
    2008 GS , MSD 8.5mm Super Conductor Wires (DIY) - Autolite Iridium Extreme Sport Spark Plugs #XS4162 Stock BLACK/SILVER
    Default Here's what I did...
    I have an RS which is the same basic design. With the spyderpops heat control I have no problem with the heat. The radiator foam wrap and the deflector work great I added some 11/2"and 2" holes to the bottom panels and ryde with Light lace on and blue jeans.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Active Member Docster's Avatar
    May 2017
    Perry Hall, Md
    Quote Originally Posted by Demndawg View Post
    Kudos to you for at least attempting a search. You're correct about what you found. Hope you find a solution
    2011 Spyder RT-S
    LtCol, USAF Ret
    Proud Patriot Guard Rider
    2011 RT , Yes Blue
    Feb 2012
    Spring City,Utah
    Now i want to see you with light lace on oh you meant boots
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Dec 2008
    Connecticut
    I have an original year 2008 GS Manual and I like to ride in shorts. Me and jeans in the summer just doesn't work. I found a solution to the problem on the really hot days. In Sept I got a new 2018 Sea Doo GTX 230, a little pricey but has solved the problem. Really hot days I'm on the Ct River, not so hot I'm on the Spyder. Its really hard to say which BRP toy is more fun, the GTX does 70mph. One of my Spyder riding friends bought a Jet Ski as well. Cant wait for the warm weather !!
    Also agree...good riding pants and boots are a great help if you are not doing it already.
    The gasket replacement is also right on.
    Active Member Nobodyjj's Avatar
    Sep 2018
    Caledonia,Ontario,Canada
    Lets hear more about the holes in the belly pan or just plain removal.
    Jun 2015
    Hillsboro, Ohio
    Quote Originally Posted by hillrad View Post
    ALERT! Found mouse nest in airbox partially restricting air filter. Removed mouse debris and installed new filter... improved heat issue.
    Fog lights
    Auxiliary power
    Rivco - floorboards
    Easy Risers
    Frunk light
    Wool seat cover
    Rear rack bag
