Results 1 to 9 of 9
Hybrid View
    May 2018
    Columbus, Ohio
    Default BajaRon ASB install
    Hi folks,
    Got our anti-sway bar and end links installed a couple of days ago. Nothing new to report here, just the same comments registered all over this site: what a tremendous improvement in stability and corner handling. Mush flatter in the turns.
    2016 F3 Limited in Pearl White-LaMonster GPS mount, LED fog lights, BajaRon anti-sway bar, Doc Humphrey's vibration dampener
    2013 Harley Davidson Softail Breakout CVO/ 110ci of potato-potato goodness
    2016 Ducati Xdiavel/ A street demon with a belt and forward controls
    Faribault, MN
    Or is that less mush in the corners Congrats on a much admired improvement.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    May 2018
    Columbus, Ohio
    well, you got me there....your description is more accurate !
    Thank you very much for your kind words. The sway bar is a great mush remover! You shouldn't have much mush from here on out! (Sorry, couldn't resist).
    Default Congrats
    What can we that have it say... you installed it , you tested it...you know..!!
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Nov 2015
    Myerstown, Pennsylvania
    Kudos to BR for awesome products!!!!!!!
    I got an oil change kit for a 1330 from Ron too. Top of the line!
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
