Results 1 to 15 of 15
    Active Member Bigmo's Avatar
    Apr 2018
    Corpus Christi Texas
    Default More light for "Blondie"
    2018 RT Limited "Blondie"
    Very nice. You cannot have to many lights.
    Default Way to go...!!
    They will see you coming now... nice job and know your feeling good now that your done....for now...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Sep 2015
    Parkesburg,Pa
    Nice job,more lights are always worth the time invested.
    Aug 2008
    MA & NH
    Looks good.
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default Looks good...
    ...and I agree that more lights - front and back - make us more visible to the cagers. I'm going to add Lamonster's Longhorn turn signals to our 2010 RT - wanna see and be seen... Nice job on the install...
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Faribault, MN
    What are the lights on top of your A Arms? No chance of the light hitting the body at full deflection (full shock compression)?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Feb 2017
    We installed those lights on both our Spyders and can say that they've caused absolutely no trouble over the 2500 miles they've been in place.
    Faribault, MN
    Quote Originally Posted by Arion View Post
    What lights? The A Arm leading edge LED's or the as yet unidentified mystery lights on top of the A Arm?
    I'm actually asking what make / model / size /type of light it is mounted above there. I DO see two different examples in mbenazerafMore light for "Blondie" post #1, and in the later post by Big Guy66.
    No one has said which lights they installed on top of the A Arm.
    I checked their sig block too just in case they listed them there.
    Safe Rides,
    IBA 70020
    Apr 2018
    Plenty of space. No problem with compression. Just got to be very careful where to drill a small 1/4" hole for the bolt. Link below.A-arm light.jpg
    https://www.ebay.com/itm/2X-4INCH-54...72.m2749.l2649
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default Legal?
    Are all of these add on lights legal to ride with on? I know in NY, if the vehicle didn't come from the factory with the lights on it, you could be ticketed.
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Vermont
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Dec 2015
    Oakley Utah
    Quote Originally Posted by mbenazeraf View Post
    Those lights are huge, more than twice as big as the lights normally mounted on the A-arms. I hope you have them tied into the high beam switch or can otherwise control them independently of the ignition switch.
    2014 RTL Platinum
    Apr 2018
    Default "Blondie" is happy now...
    May be too bright? Both top & bottom light are wired through a switch and relay, straight from the battery, Light1.jpgLight2.jpgLight3.jpgLight4.jpgindependent from the bike lights. I can control the blue halo by its own switch.
    Apr 2018
    Quote Originally Posted by FINFAN3DP View Post
    NY needs money desperately. They'll do anything to get it....
