Results 1 to 8 of 8
    May 2016
    Winnipeg, Manitoba, CANADA
    Default No Start -- after changing headlight bulb
    Yes, you read that correctly. All I did was change my headlight bulb. Now the bike won't start.
    Battery is good.
    Kill switch is where it's supposed to be. I even tried it a few times rocking it back and forth just in case the insides were gunked up.
    Fuses that I can pull out are all good although R5 was warm to the touch. I have no idea how to get it out nor what to look for.
    Any suggestions? The Service Manual talks about BUDDS -- of course I don't have that.
    Jun 2010
    Las Vegas
    What is it thst you don’t know how to remove, the fuse? Just pull the fuse out with needle nose pliers. You should have spare fuses in the fuse box cover. You can pull the relay out as well and swap it with another to check it.
    Other than that I’d retrace the steps you took to change the bulb. The ST is not the easiest bulb to change. Good luck.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    May 2016
    Default Changed headlight -- now won't start
    What is it thst you don’t know how to remove, the fuse? Just pull the fuse out with needle nose pliers. You should have spare fuses in the fuse box cover. You can pull the relay out as well and swap it with another to check it. Other than that I’d retrace the steps you took to change the bulb. The ST is not the easiest bulb to change. Good luck.
    Thanks. I'll try doing that. It's not a regular mini-fuse … it's a large black R5 … relay, perhaps? I don't want to have to go back in to the headlight area. That is an awful area for a person with large hands. Eccchhhhh ….
    Oct 2011
    Kalamazoo, Mi
    Default no start
    Quote Originally Posted by MurrayBrown View Post
    MB, It is a little(ok a lot more) wrenching but if you disassemble the front section from the frame, you will then be able to tilt it up and forward and easily access those nast headlights from the underside with all the room you would like to work with. Alot more disassembly but worth it for the reductions in cuts, scrapers and needed cuss words to complete the task!!!!
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    May 2016
    Quote Originally Posted by IGETAROUND View Post
    Al in Kazoo
    Hahahaha! Thanks!
    May 2016
    Default Changed headlight -- now won't start -- SOLUTION -- Kill Switch
    Well, the issue is RESOLVED.
    When you're leaning in the handlebar area, make sure that you don't inadvertently hit the kill switch.
    If the kill switch is in the OFF position, there is no way that your bike will start! :-) :-)
    Jul 2015
    Dorr, michigan
    Good news!!
    So in your OP when you said "Kill switch is where its supposed to be", you were just telling us it was on the right handle bar, correct?
    I can laugh because that one gets me every now and then after working on the Spyder!
    2020 RT Limited , Petrol Blue
    Dec 2015
    Oakley Utah
    Yes, you read that correctly. All I did was change my headlight bulb. Now the bike won't start.Battery is good. Kill switch is where it's supposed to be. I even tried it a few times rocking it back and forth just in case the insides were gunked up.
    In light of the final solution, this is a little perplexing....
    2014 RTL Platinum
