Results 1 to 6 of 6
    Active Member Many brands's Avatar
    Aug 2016
    Atwater, California
    Default Oil Change - why 2 drain plugs??
    Two plugs to do the oil change.. One is a "Sump Tank" ? And one is the "Motor Pan" ? When re-filling, the oil of course fills them both? Whey then two plugs ?
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Without two drains there would be old oil left in which ever didn't have the drain. I guess a simple way to think of it would be to think of one as a drain for a storage tank and the other as a drain for the place where the oil is used. Each has oil in it.......at least they should........and each needs to be drained separately.
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    I won't say much, except you may want to Google "dry sump engine design"
    then you will be able to sound informed.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Idaho
    Quote Originally Posted by Many brands View Post
    One is the sump of the motor proper. The other is in the clutch cover. It's two reservoirs of oil, one for the engine and one for the clutch. The oil circulates through both but they are not one reservoir.
    2014 Copper RTS
    Aug 2007
    Greeneville, TN
    2 oil compartments. 2 drain plugs. 1 fill point.
    The Spyder uses a 'Dry Sump' oil system. This is to reduce the overall size of the engine. In a car the oil reservoir is in the pan which extends quite a ways below the engine. With the Spyder, this 'Oil Pan' is relocated remotely to a more appropriate area making the engine smaller and able to be mounted lower in the frame. This lowers the center of gravity and seat height, among other things.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Dry sump engines also maximize horsepower and torque by reducing what is commonly called "windage loss", although that term is not technically correct. (It should be called hydrodynamic loss.) This refers to the loss of power when the crank and other moving parts in the bottom of the engine meet resistance inside the oil bath of the sump.
    https://en.wikipedia.org/wiki/Windage
    2020 RTL SE6
