Results 1 to 25 of 38
    Mar 2015
    forrest above Reno, Nv
    Question LED headlight failure
    After a 2000+ mile trip through the south west------ one of the LED headlight bulbs is out. I'll pull the plastic off and check connections. Then the light bulb if necessary.
    Has this happened to any one else ( one bulb ( LED ) dead with in a few months of install)????????
    If so----- did the supplier replace it????
    Thanks in advance,
    Lew L
    2014 RTS , Circuit Yellow
    Sep 2014
    USA
    Check with your supplier you may geta replacement from them.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Lew L View Post
    After a 2000+ mile trip through the south west------ one of the LED headlight bulbs is out. I'll pull the plastic off and check connections. Then the light bulb if necessary. Has this happened to any one else ( one bulb ( LED ) dead with in a few months of install)??? If so----- did the supplier replace it???? Thanks in advance, Lew L
    Yes, that happened to me last September at NoCal Spyder Rally. It was a TricLED and Squared Away replaced it for me no charge, even though I had not bought it through them originally. Subsequently, there was a thread about this and apparently it's fairly common. Usually it's the left side bulb that fails but there was not enough of a pattern of failures to draw any conclusion from it.
    Jane's Spyder also suffered a burnt-out LED bulb shortly after we bought it used. That was a different type and manufacturer of LED bulbs and I replaced both with TricLEDs and have experienced no more failures.
    2014 RTL Platinum
    Mar 2015
    Yes Pete,
    It was the left side bulb. Just no reason that it should be one side or the other????? I think it was Lamonster where I purchased the bulbs but I can't fine the paper work, yet.
    Contacting Lamonster next.
    Lew L
    PS: Lamonster now has the ball. Hope he can work something out.
    Dec 2015
    Oakley Utah
    Yes Pete, It was the left side bulb. Just no reason that it should be one side or the other????? I think it was Lamonster where I purchased the bulbs but I can't fine the paper work, yet. Contacting Lamonster next. Lew L
    Lamonster's have the 'black box' outside the headlight housing. TricLED's fits inside the housing.
    2014 RTL Platinum
    Default Bummer.....
    Only possiblity would be the lenght of the wires to the bulbs. One is usually closer to the harness and LED's are touchy... Don't have them myself but my halogen's Left side have gone out after every long trip..
    Dec 2015
    Oakley Utah
    Yeah, there have been all kinds of theories, but nothing definitive.
    2014 RTL Platinum
    Oh c'mon, it's obvious..... that's the side of our mouths we all stick our tongues outta while we are concentrating!! So of course that's the side the light blows on.... more drool on the connections!
    Dec 2015
    Oakley Utah
    Yeah, that's one of the theories I'm talking about
    2014 RTL Platinum
    Vermont
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Jul 2010
    Las Vegas, NV
    Default Lights
    Lamont stands behind his stuff. Never had any issue.
    Call him.
    Joe Meyer
    Springfield, MO
    Yes Pete,
    Lew L
    We got your email and Jacob sent you a reply. We do not and have never sold a LED headlight with the fan built in so it wasn't bought through us. We have replace quite a few bad ones. Our headlights come with a factory warranty of two years. I think we've replaced maybe four in the years we've been selling them. Give us a call.
    Mar 2015
    Smile
    I haven't found the paperwork yet. Must have been brand " T" I purchased from and I'll check. I wonder if the 4 you have replaced were the "left" side headlight as discussed above??
    Lew L
    Dec 2015
    Oakley Utah
    I haven't found the paperwork yet. Must have been brand " T" I purchased from and I'll check. I wonder if the 4 you have replaced were the "left" side headlight as discussed above??Lew L
    Now we know it's the type with built-in fan, maybe someone here can identify it for you.
    2014 RTL Platinum
    Mar 2015
    Well it was from TrickLED and I'll contact them. Sorry to all about any confusion.
    Lew L
    Jun 2010
    Las Vegas
    Lew L
    And I’m wuite sure they will have a replacement out to you today.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    They're good folks, who also stand behind what they sell!
    Dec 2012
    Casa Grande,AZ
    E-mail a picture to Cindy at Tricled and she will send a replacement pair.
    I've had three go bad since September last year and had replacements to me in a few days the last ones are the new 360 degree leds.
    Just last week I had the mirror mount turn signal led start to fail and I had a new set in about three days.
    Gary
    Springfield, MO
    Lew L
    Well we've sold a couple of thousand of these and if it was a left side issue I'm sure we would have seen more than that.
    May 2013
    Edmonton Alberta, Canada
    I had one go out fairly quickly and another about 2 years in.
    They replaced both with no problems at all!
    I believe their bulbs carry a lifetime warranty!
    2014 RT-Ltd , Cognac
    Mar 2015
    Thumbs up Super Service
    Yes, I did purchase from Tricled. Invoice sent and now paid for. Just a matter of shipping and install. Cindy at TricLED is great, she made it all right with no delay. Thank you Cindy.
    Lew L
    Going on a year with mine. No problems yet. Mine are TriCLED's. I bought mine because the OEM (right side) had burned out twice in three years.
    Thought you would have no problem with TC. I am glad to see they already stepped up.
    Dec 2015
    Oakley Utah
    Yes, I did purchase from Tricled. Invoice sent and now paid for. Just a matter of shipping and install. Cindy at TricLED is great, she made it all right with no delay. Thank you Cindy.Lew L
    Let us know how you like the new 360 bulbs.
    2014 RTL Platinum
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    I am interested to see how you like your 360 bulbs. I am interested in them as well.
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    May 2013
    Quote Originally Posted by Dmetcalf View Post
    I just put a set of the 360's in a buddies RT, he loves them!
    He lives out in the country, does a lot of night riding and says the spread of the lights is great and covers both ditches!
