Results 1 to 25 of 40
    Active Member SpyderBears's Avatar
    May 2016
    Chesterfield, MA
    Default Questions about toy haulers
    We're wondering if anyone out there has a 5th wheel toy Hauler RV for their Spyder. Wondering if a Spyder RT can be driven up the ramp. They seem really high off the ground and at a steep angle. Concerned that the angle is too steep for the Spyder front end.
    Any thoughts? Experiences? Advice?
    Thanks!
    Nate and Lori
    2021 Spyder RT Limited--Deep Marsala Red--Chrome Edition
    [/B]​Nelson-Rigg half cover, Hopnel side bags and trunk liner bags, , Driver's Backrest, BRP Trailer hitch and control module, 131 DB horn from TricLED, "Shadow" trailer from Mini Trailer USA,
    Class C rig here...
    We've got a nine-foot garage, and it's TIGHT!
    But it works!
    I have ot raise the rear of the ramp up about two inches, to lessen the breakover angle a bit,..
    I also use some 42" short ramps, to get the front wheels started.
    Most of the 5th wheel rigs have larger garages (10 to 18 feet!); so fitting in won't be a problem.
    They also have longer ramps too!
    Active Member soaring hawk's Avatar
    Feb 2011
    Mankato, Minnesota
    Default Toy hauler
    We have a 10’ garage sometimes I have to lift the front of the camper up to change the pitch.
    also pump up the rear shock to the top helps.
    Heartland tourque has a 1’ 1/2 dove tail to help.
    Gary
    All I want to do is ride!
    Active Member Navvet's Avatar
    Apr 2016
    NC
    I had a problem with my Goldwing and the SPYDER.
    I have a 10' garage so the fit is not an issue, just getting up the ramp.
    I replaced the bumpers with 1,000lb rated trailer stabilizers and then added a HF 1,500lb ramp hinged to the camper ramp.
    It's not pretty but it's got a nice solid run-up with very little hump. Easy to get in and out.
    2013 F6B
    2016 F3 Ltd
    2016 F3 LTD , Triple Black
    Dec 2014
    United States
    Default toy hauler
    Quote Originally Posted by SpyderBears View Post
    We're wondering if anyone out there has a 5th wheel toy Hauler RV for their Spyder. Wondering if a Spyder RT can be driven up the ramp. They seem really high off the ground and at a steep angle. Concerned that the angle is too steep for the Spyder front end.Any thoughts? Experiences? Advice?Thanks!
    We have a 45ft. Momentum 5th wheel and the only thing I have to do is put down to 2X6 to raise the front wheels so that the bottom of the front frunk does not hit the ramp. We have trailered the spyder from PA to GA this past year and have plans for NM, and Sturgis. We installed a winch so that I could load it without having to drive it in and it works great. Sorry I don't have any pics but you can contact me
    Jul 2016
    Arizona
    Default Toy hauler
    I have the Heartland Cyclone with the 10ft garage that has the dovetail. No issues loading or securing my F3L. The toy hauler is for sale..2007 Cyclone 3210 5th wheel. I'm in AZ.
    Aug 2012
    CO
    Our Keystone Fuzion 310 had the 10ft garage. Never bottomed out once. Did scrape the nose one time though. But no problems with any level RV park site.
    JLohPhotos
    2008 GS , Millennium Yellow
    Quote Originally Posted by Navvet View Post
    Tell me a little bit about those 1000 pound trailer stabilizers: I'd like to be able to not have to "block up" my ramp...
    What are they, and where'd you get them?
    Apr 2016
    NC
    What I used was https://www.trailerpart.com/p-4763-2...s-and-rod.aspx
    Adjustable and fold flat when not in use.
    Several companies make similar but I found these to be simple and inexpensive and being adjustable make them easy to use in some of the "non-level" campgrounds.
    Please excuse the dirty camper, that was taken just after a 2 month cross country trip.
    2013 F6B
    2016 F3 Ltd
    Dec 2015
    Oakley Utah
    I had a problem with my Goldwing and the SPYDER. I have a 10' garage so the fit is not an issue, just getting up the ramp. I replaced the bumpers with 1,000lb rated trailer stabilizers and then added a HF 1,500lb ramp hinged to the camper ramp. It's not pretty but it's got a nice solid run-up with very little hump. Easy to get in and out.
    Nice solution.
    2014 RTL Platinum
    After reading about those lifts: they're a bit too tall for my application...
    But I found another option on E-Bay:
    I just need to check with the vendor about the bolt-spacing on them...
    https://www.ebay.com/itm/6-Rubber-Bu....c100290.m3507
    Owatonna, MN
    Default Spyders in Toy Hauler
    We just got back today with our Momentum 394M and we put an F3 and an RTS in the 12 1/2 foot garage. I drive the F3 in forward to one side and back in the RTS to the other side. The trick is to go at an angle, get one of the front tires on the ramp, and turn the handle bars and drive in. Backing in is trickier but use I the same technique. By getting one tire started on the ramp first the nose of the Spyder also lifts higher and doesn't hit the ramp. I am able to load both Spyders while level and the toy hauler hooked up to the truck. If the ground is not level, just raise the front of the toy hauler a little to make the ramp less steep.
    Did you have any traction problems, when backing up the ramp?
    I couldn't get mine to take a bite, and keep climbing...
    May 2013
    Indiana
    Just wondering, does having a bump skid make loading a bigger problem???????
    Mike
    2021 Marsala Red Metallic RT Limited
    It cuts down on your ground clearance a bit: although I haven't found it to be a problem.
    Owatonna, MN
    My toy hauler is new so the rear ramp has a good amount of traction. To back up I do need a little momentum to get over the initial tires going onto the ramp but don't have problems after that. If the rear tire is wet there might be some issues but I have not had that problem yet.
    Thanks! You're right: a rear wet tire allows stuff to start sliding around a bit...
    May 2016
    Chesterfield, MA
    Very interesting setup Navvet. Did you buy those extra 2 ramps or build them?
    Nate and Lori
    He did say that he used these:
    With that link: I'm guessing that he bought them.
    Active Member ingramsail's Avatar
    Aug 2012
    Oklahoma City, Okla.
    leveling blocks for rv's work and are easy to store. Did make one change, l now use a tapered stack of 2 2x6's 20in. long with pins to keep the center blocks from moving.
    I've got a Lippert System: no leveling blocks...
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Quote Originally Posted by ingramsail View Post
    I use a very similar system that you use here. I use longer and a bit wider (2x8) and about 6ft. Long and run them up about 3 ft. On the outside for my two front tires to run up on the ramp so that works to keep the nose up high enough to not strike the ramp and I have a similar 2x6 to allow the rear wheel up at the base of the ramp like you have. Works well. I did taper one end of the 2x8’s to allow the front wheels to get up on them easier.
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    I use a 5" high rubber curb ramp for the rear wheel, and some 42" length 2"x8"s: for the fronts!
    Apr 2016
    NC
    The extra ramp is a Harbor Freight folding ramp attached with hinges and a sheet of OSB laid over to give a smooth surface.
    2013 F6B
    2016 F3 Ltd
